-   -   Will this boat do 90mph??? (https://www.offshoreonly.com/forums/general-boating-discussion/58972-will-boat-do-90mph.html)
OG Outlaw 24 09-11-2003 08:12 AM
Link to boat
http://ebay3.ipixmedia.com/abc/M28/_...a7/i-1_B_L.JPG
OG:cool:
OldSchool 09-11-2003 08:20 AM
Maybe....on the trailer:D :D :D I would think that it would need a little more HP to get it to 90.
CigDaze 09-11-2003 08:24 AM
Ya, no problem. Wax the bottom and it may even do 100.
NOT! :D
HiPerf2000 09-11-2003 08:46 AM
I saw that one last night on ebay.
Sometimes you have to wonder....If the owner is lying about speed figures, what else is he lying about????
he is throwing credibility out the window.
BLee 09-11-2003 08:49 AM
No way, not even close. Funny it doesn't show a pic of the motors.
otis311 09-11-2003 09:12 AM
As troutly said 75, MAYBE, Maybe 80, but i doubt it
Cord 09-11-2003 09:26 AM
That's the advantage of those pitot tube speedos! :D
WickedWon 09-11-2003 09:58 AM
Why Not !
Faria gauges RULE !!! :D :D
45sonic 09-11-2003 11:29 AM
Downhill on a trailer. Not unless it has twin 900's. I agree with Troutly 75-80 mph. A friend of mone has a 311 with T-460's @ 600hp that will only reach roughly 80. O well, we all add a little to our top end speeds
:D:D:D:D
MnHowardCat 09-12-2003 04:54 PM
I'LL say ON WAY;)
packinair 09-12-2003 05:00 PM
yup.. and drill it out a bit and there is no cheeper way to pic up 25 mph
Ryan Beckley 09-12-2003 05:36 PM
drop it off a cliff and it might.
wwwTOPDJcom 09-12-2003 05:43 PM
EVEN IF IT COULD there is NO Hydraulic steering:eek:
which is NUTS !!!!
wwwTOPDJcom 09-12-2003 05:47 PM
ok will this 29 baja with 454 mags stock do 81
http://adcache.boattraderonline.com/6/0/0/53239100.htm
birdog 09-12-2003 05:52 PM
Yes !
If i put a chip in my PSD !!!:eek:
glassdave 09-12-2003 09:21 PM
(in my best Al Borlan voice) . . . . "uhhh . . . .i dont think so Tim"
looks like a nice package for the money though.
wilerty 09-12-2003 10:18 PM
Hi Brian ... Maybe mid 70s for the Baja. The 29 Outlaw has a lot of room and is a decent setup with that power.
mopower 09-12-2003 10:47 PM
You would need 30 " maybe 32" Bravos to do that and unless he's sprinning his engines to the moon , he won't do 90 with those props
32storm 09-13-2003 07:38 AM
Looks like a nice package, but 90.....90....90...ah,ha,ha,ha, ha, ha.
80 is more like it on a good day.
Pure Energy 09-13-2003 08:44 AM
I e-mailed the seller and he confirmed the speed. I also asked what props and he said they are 25p 3 blades.
I know someone with a 38 Formula with 540s, stellings boxes. He said that he was told it is tough to get a Fomula over 80 mph because they have a hook. Is this true?
bowtie 09-13-2003 10:58 AM
You would have to be turning those engines close to 6500 to reach 90 with 25's
jpclear 09-13-2003 02:02 PM
FYI -- The size of the pitot inlet really has nothing whatsoever to do with the #'s/sq. in. of water pressure that the speedo gage measures. Then the dial on your gage is calibrated in MPH rather than #'s. --- Jer
sean stinson 09-14-2003 04:18 AM
Assuming these factors here are the speeds it's capable of;
At 5000 RPM
1.36 gear and 25 pitch prop
at 7% prop slip = 80 mph
at 12 % prop slip = 76 mph
1.5 gear and a 25 pitch prop
at 7% prop slip = 73 mph
at 12% prop slip = 69 mph
At 5500 RPM
at 7% prop slip = 89 mph
at 12% prop slip = 84 mph
1.5 gear and 25 pitch prop
at 7 % prop slip = 80 mph
at 12% prop slip = 76 mph
At 6000 RPM
at 7% prop slip = 97 mph
at 12% prop slip = 91 mph
at 7% prop slip = 88 mph
at 12% prop slip = 83 mph
It's possible but not probable. Need more HP IMHO
Sean
mcollinstn 09-14-2003 07:03 PM
jp's kind of on the right track - Speedo pitot diameter has no effect on the line pressure to the speedo head.
Big hole, little hole - the only reason the pitot hole isn't larger is that it would slow the boat down.
That is why you can use any brand of pitot and get the same result. I've seen hole diams from 1/16" to 3/16".
You gotta remember that the water in the line isn't moving at a steady speed. It is not a flow consideration, just a route for sampling of water pressure at speed.
With that said, NO, I don't believe this boat will go 100. Or 90. Or 80.
enticer 09-14-2003 07:08 PM
Talks up all the money in the motors and then there is not even a picture of them (High Priced Things)
NO
Madcow 09-14-2003 08:17 PM
Friend of mine just sold his 311 with 625 Sterlings. Boat went 82 on a GOOD day. And these were Sterlings. He dosn't say who built his. My guess is NOT EVEN CLOSE!!
Madcow 09-14-2003 08:18 PM
Re: Why Not !
Hey... I have Faria gauges. 'Course my boat is slow and rattly.:D
