Which Aeromotive fuel pumps do I need???
I went to re-wire the pumps because they are loose and corroded, my fuel pressure guages are bouncing. Tried to loosen the nut to get the wires off and they are rusted tight and the stud spins, so I can't get them off!
The pumps I have are Aeromotive but have no numbers or anything on them. I am going to replace but not sure what I need. I have done some research and found part# 11108 & 11101. Is there a diff. Motors are procharged 502s, 6 lbs boost. Thanks |
I am not sure of the part numbers but you need the ones that are in line and the regulators...I will try to dig up the part numbers but if memory serves me correctly you need the #11108 unit which should be one with a little more pressure.
| All times are GMT -5. The time now is 05:37 AM. |
