-   -   2-by or 4x4 (https://www.offshoreonly.com/forums/general-boating-discussion/61612-2-4x4.html)
105mph_38_2003 10-17-2003 05:14 PM
In my dually I have had to use 4wd just to get across wet grass. The heavy front end and light rear end makes the rear tires spin quite easily.
BadDog 10-17-2003 05:38 PM
Even without the manual lockout hubs you can usually defeat the front axle from locking up. Often times you just need to interrupt an electrical circuit. On most late 90 Chevy trucks pull fuse # 24. Low range is often very nice especially if it is 2 WD. Ever try to turn on dry pavement in low lock?
Pure Energy 10-17-2003 05:40 PM
1 Attachment(s)
4X4, no question!!!
CAP071 10-17-2003 07:35 PM
All I can say if you don't get a 4x4 You will be sorry one day you didn't .
:eureka:
Fuhgedaboudit 10-17-2003 08:12 PM
gee, I dont know...I pull a 357sr1 formula on an eagle galvanized tri axle trailer, total weight around 11,000 pounds with a 2wd CREW CAB GMC dually with an 8' bed and a 454 with an automatic 4L80E. Never even spun the tires at the ramp in low gear, just pull out slow and easy...
Fuhgedaboudit 10-17-2003 08:14 PM
I think the difference is having the longer wheel base...what do you think?
ragtop409 10-18-2003 01:02 AM
1 Attachment(s)
4X4 :D Rag's
East Coast B 10-18-2003 05:46 AM
4x4 all the way!!!
cuda 10-18-2003 06:47 AM
Having four wheel drive is kind of like having a pistol. You don't really need it until you need it badly!
R Addiction 10-18-2003 07:24 AM
105......Your picture looks like you ran over someone!!!!Nice truck!!!:p
