ot,Testimony to an A300B4 (Missile Damage to Airbus A-300)
1 Attachment(s)
To those of you who are wondering what happened to the DHL A300B4 coming
: out : of Baghdad last Saturday, take a look. Aircraft was hit at 8000 FT, lost : ALL : hydraulics and therefore had no flight controls, actually did a missed : approach using only engine thrust and eventually (after about 16mins) : landed : heavily on runway 33L at Baghdad. This was fortunate because with no : steering the aircraft veered of the runway to the left, had they landed : on : 33R veering to the left would have taken them straight into the fire : station. The aircraft then travelled about 600 metres through soft sand : taking out a razor wire fence in the process, see LH engine pic, and : came to : rest almost at the bottom of the sloping area between the runway and a : taxiway. All three crew evacuated safely down the second slide, the : first : one tore on the razor wire. I flew in with a team on Tuesday in one of : our : Metros and some special equipment we'd had made locally in Bahrain and : some : provided by Airbus. Using a USAF D9 Caterpillar pulling a 100 metre : cable : fitted to the back end of each bogie and a nice new aircraft pushback : tug : with a towbar on the nose gear, we were able to remove the aircraft just : on : dusk on Tuesday night and towed it to an Iraqi Airways graveyard on one : side : of the terminal. We stayed overnight in the USAF camp on the airport and : went back to the aircraft on Wednesday morning to allow the insurance : survey : to be completed and then secure the aircraft. Basically, LH engine : rotates : in a fashion, has ingested lots of razor wire and is knackered. RH : engine : has seized, probably from ingesting loads of sand at maximum reverse : thrust : and inlet cowl has unacceptable lip damage, probably from hitting the : razor : wire fence posts. The No 8 axle appears to be cracked as the wheel sits : at : an odd angle. The bulk of the damage is the LH wing. About 3 metres of : rear : spar is missing in front of the outboard flap, the wing has bulged : upwards : and downwards where the initial explosion appears to have occurred, one : O/B : flap track is hanging in the breeze and one has a small piece of flap : still : attached, the rest of the flap is nonexistent. The pics show the huge : crack : that has occurred to the rear spar inboard of where the spar has burnt : away, : possibly from loads on the wing during the landing process. The front : spar : appears to be intact. The point of entry pics show where a projectile : entered Tank 1A, which was full of fuel, and, after it ignited, : proceeded to : burn away at the spar. The fuel tank ribs in the area directly in front : of : the O/B flap are burnt almost 50% through. The crew obviously did a : fantastic job in getting the aircraft back on to the ground and one can : only : assume that it was most fortunate that they were not aware of the state : of : the wing as they could not see it from the cockpit. It also says a lot : for : the structure of the aircraft that it withstood the impact of the : (whatever : is finally determined to have hit it). : : I'm sure there will be lots of other photos and videos flying around the : net, but at least these ones are genuine. The worst part for us was the : airport was shut down on Wednesday and we had to be driven in an : armour-plated Landcruiser Troop Carrier from Baghdad to Balad, 60 miles : to : the north, from where we flew back to Bahrain in our Metro again. I : trust : you will all appreciate just how lucky these guys were. Regards, : : DHL International Aviation, |
1 Attachment(s)
Point of entry
1 Attachment(s)
spar
1 Attachment(s)
tire
1 Attachment(s)
fan blade
1 Attachment(s)
lh wing
1 Attachment(s)
wing
WOW, were they able to jettison or did the rocket do it for them?
My respect goes to the crew for the improvised landing. |
An incredible story of skill and luck, indeed. :)
| All times are GMT -5. The time now is 03:43 AM. |
