Any Guesses on speed
I am currently running Merc 6a's (wet) with 598 c.i. Cobra's 1671 airlock blowers, 7to 1 comp. ratio. 92 octane. 1100 h.p. ,1050 ft. lbs of torque. 40 ft. Skater at 10,500 lbs. Current speed with 16.5x37 Rolla's is 143 mph on gps with 1oo gallons of fuel and 2 people on board. I am going to Dry sump drives, Change pullys from 9 lbs of boost to 12 lbs of boost and burn cam 2. I am also changing drives from 135 gear ratio to 124 ratio. Am thinking 16.5x35inch 4 bladers. Any guesses on speed? Motors should produce from what I am told about 1400 h.p.
Stan |
Stan-
Have you used the speed calculator on Marc/ Bam's site? I've found it to be helpful Due |
Forgot to ask: what engine RPM did and will you turn?
Due |
ssorry, thought about it while outside smoking a deer hind-quqrter. 6100 r.p.m.
Stan p.s. I think we were at about 10% slip |
thuoght that was david wade power:confused:
David worked with Randy on project. Randy has engines right now freshening them up after Orange Beach
I think if you plug all that back into Bams sight the computer will start to smoke and the site will crash :D:D I am going to give ya 10-15mph increase
Jon |
How do you get to marc/bams site
Stan |
Stan-
Using your existing specs and speed, according to Bam's calculator you're running 10% slip: as you said. Using the new info: ratio and your -existing pitch-, the new speed would be about 155 at 6100 rpm. My guess is to try your existing prop before changing to less pitch. At least that will give you a base line. Here's the link: http://www.go-fast.com/Prop_Slip_Calculator.htm He has other "calculators" on his site too. Due |
thanks guys
Stan |
low 160's
Stan-
One other thing, isn't 10% slip high for that Skater? How many blades on your props? Due |
4 blades , it might have been 8% David Wade knows for sure and he will be here at 3 to start getting ready for LSU game and I will post then.
Stan |
| All times are GMT -5. The time now is 04:43 AM. |
