-   -   OT: Best anti-fog method (https://www.offshoreonly.com/forums/general-boating-discussion/66000-ot-best-anti-fog-method.html)
Risk Taker 12-11-2003 02:23 PM
I just got new RecSpec sport glasses to go under my ice hockey helmet. Played last night with them for the first time and had quote a fogging problem.....
I know there are sprays out there that are supposed to help, but I was wondering if anyone had a different "Homemade" solution........
Thanks.....:D:cool::cool:
MitchStellin 12-11-2003 02:35 PM
You need to stop breathing:D You must have a lexan guard, right? You need to ventilate as much as possible. I have seen holes drilled into the guard at the top to let more air out. If there is no guard try and get the glasses to not be so close to your face.
Chris288 12-11-2003 02:45 PM
Risk,, I went through the same thing, had a couple different shields,, CCM and forgot the other but they were both pretty expensive,, tried anti-fog cloths, sprays, nothing worked very well, ended up going back w/ the stock wire mask. In your case, I would try fog-stop or somthing similar from the hockey store,, it's a PITA..
GLH 12-11-2003 02:52 PM
Re: OT: Best anti-fog method
Originally posted by Risk Taker
I just got new RecSpec sport glasses to go under my ice hockey helmet....
Evolve into the 1960's and wear contacts. :crazy:
CigDaze 12-11-2003 02:54 PM
I used to use "FOG-X" a product made by the same company that makes Rain-X for cars. You can find it in the autoparts store.
It'll work grear on you glasses, just be careful when using it on plastic...it may mar the surface.
Risk Taker 12-11-2003 02:57 PM
Chris - I'm going tonight to get a wire shield, and combine that with some fog stop for the glasses. Hopefully that will work. Thanks for the input.
GL - I had a very bad experience with contact lenses back in the early '90s.......I put a set in backwards one time and thought Mr. Happy had disappeared !!!! No more for me..........:D;)
BigSilverCat 12-11-2003 03:01 PM
this sounds gross but it works better then anything else spit on the lens and rub it around and then lightly run water over them. it will work better then any of the sprays you can buy. any scuba diver will tell you that is what they do.
Risk Taker 12-11-2003 03:01 PM
Nick - the lenses are Polycarbonate......
CigDaze 12-11-2003 03:18 PM
Oh well...scratch that idea. :)
Chris288 12-11-2003 03:23 PM
I ruined a CCM shield w/ a rain X product that said it was safe on the plastic,, it wasn't , melted it REAL BAD. called up the company and they had a check in the mail in no time.. As much as I like the shields, they scratch, and fog so I gave up on them and now just use the wire cage..
GLH 12-11-2003 03:30 PM
Spit in'em.
With your mouth.
HiPerf2000 12-11-2003 09:57 PM
i use baby shampoo on my motocross goggles. rub it on and it leaves a film that helps stop the fog.
