Vagrant,
Is you F-350 a powerstroke? 4WD? Extended/crew cab? What color? Might have interest in the future. Thanks, RedDog382 |
Sweet, look at the F 650's too...But if you can get one of these for $31k that is about 1/2 the cost of the Ford.
1 Attachment(s)
Red Dog,
Here is what I have now. The truck has 122,000 the price will be in the 17,000 range |
1 Attachment(s)
pic 2
Warparty36 and I towed a buddies 47 Fountain to Destin FL. last Summer. When they put the boat on the slings it weighed 21,000 lbs, no ****. He has a transport trailer for it. It probably weighs 5-6,000 lbs. So around 26,000 lbs total.
We pulled it all with no problem with a 2003 3500 Chevy Dually, Duramax. Unbelievable. |
1 Attachment(s)
I would get this one!!!
:D
The bigger trucks are real nice . The most common mistake is not getting enough GEAR in the rear to run ! Most are geared low and the motors turn low rpms .Our kodiak had a 250 cat with taller tires and it would top out at 76mph wide open . That's not enough . You need it geared to run about 15-20 mph faster then you drive so the motor is not running wide open all the time . The motor has plenty of torque to keep it going, trust me ! If not call me and we'll "chip it " !:D Our Internation had a cummins that I turned up to 300hp . It was geared right . On cruise pulling over 30,000 lbs behind it ,it ran 85-90 mph through the mountains in Va, Ten, and Kentucky . I can't remember what gears they had though .......... Our kodiak got 10 mpg all the time . Taller gears would probably done better . You can get the air ride suspension for the back . YOU SHOULD ! I've got some great air ride seats too ! message and all ! |
| All times are GMT -5. The time now is 08:47 PM. |
