-   -   Engine Options (https://www.offshoreonly.com/forums/general-boating-discussion/70932-engine-options.html)
Kent Perroux 02-04-2004 02:13 PM
Engine Options
1 Attachment(s)
Cracked block, and need to change it out. I was looking at short block options also. Should be an interesting Poll. The least expensive will be the 1st option and going up from there.
Boat is a '83 Donzi Classic 18'. 350ci engine pushing 350hp. Bravo 1 Drive " higher x-dim than standard
Getting 70@5000. It will do close to 75 if I want to push the rpms.
If I go the short block route, I have heads, intake, carb, cam to match the flow needed. Stringers are HD and have External hydraulic steering.
Yes, I want more speed but want to maintain good handling.
Kent Perroux 02-04-2004 02:28 PM
18 classic
Bravo 1 Drive, 2" higher X-dim than Donzi Standard.
Biggus 02-04-2004 02:41 PM
I love the Donzi Classics and have owned many over the years. Fun little hot rods.
If it was mine I'd put a HP500 in it......
Just because it will fit :D
CAP071 02-04-2004 02:42 PM
Get the best you can afford! :eureka:
Biggus 02-04-2004 02:43 PM
...and if you run aluminum heads and CMI's it wont weigh much more than the stock 260 Merc with all the cast iron junk.
OldSchool 02-04-2004 03:09 PM
There is no replacement for cubic inch displacement!!!
Cord 02-04-2004 03:21 PM
I'd stick with a small block in the 18. I'd go with a 350 mag set up for a blower or maybe the merc scorpion if you have the $$.
Airpacker 02-04-2004 03:22 PM
go big or go home :)
Kent Perroux 02-04-2004 03:28 PM
1 Attachment(s)
Current engine...
PatriYacht 02-04-2004 03:37 PM
Go with a large c.i. small block. 406 is pretty easy. With World Products stuff 427c.i. / 500hp is not too expensive and all of your accessories still fit.
