-   -   Enough About Miami!!!!!! (https://www.offshoreonly.com/forums/general-boating-discussion/71821-enough-about-miami.html)
KH0302 02-15-2004 02:48 PM
OMG :eek: :(
Reed Jensen 02-15-2004 02:50 PM
Also... that debris left in the oiling system isn't a problem.... nothing unusual at all .... :eureka:
R Addiction 02-15-2004 02:52 PM
Reed, You mean to tell me that's not normal?;)
Reed Jensen 02-15-2004 02:56 PM
and he will assure you that this is normal too... he told me " you're not showing me anything I haven't seen before"...:rolleyes:
Reed Jensen 02-15-2004 02:59 PM
The best is this!!! This tuliped exhaust valve has a three angle grind on it!!!! check it out!
Hmmmm... looks like only one angle grind to me... :eureka:
2112 02-15-2004 03:00 PM
Eagle or Carrillo?
In todays world, it is almost always "someone else's fault"
Same has happened to me before. Did you catch it before it trashed everything else with in a 3 foot radius?
Reed Jensen 02-15-2004 03:00 PM
Of course this is normal "R"... Normal for the guy that built the engine... perfectly normal... :mad:
Reed Jensen 02-15-2004 03:05 PM
and the discoloration from heat wasn't because of lack of oil....... nosireeeeee! :p
Reed Jensen 02-15-2004 03:06 PM
These pictures are of a Carillo rod... nice ... huh?
Reed Jensen 02-15-2004 03:08 PM
Originally posted by 2112
Eagle or Carrillo?
nope.... it trashed the block... but the "expert" said it would be ok... and put new rods, new crank... new pistons... and a new cam into a block that had huge chunks missing in the lower web areas of the cylinders..
