Ford F-150 super screw HITCH clarification... >
Old 02-17-2004, 11:05 AM
Chris288's Avatar
Default Ford F-150 super screw HITCH clarification...
o.k. got a 2001 f-150 super screw, manual says it tows 7,200, bumper says 500/5,000, factory installed receiver hitch says class V but then on plate says 500/5,000.... So does that mean its really a class 111....
I found a class IV on etrailer.com thats rated for 800/8,000 for 189.00 bucks,, plan to tow 6,500 do I stick w/ the factory hitch or get the one from etrailer ??
Ford has me confused...
Chris288 is offline
Old 02-17-2004, 11:48 AM
Mr. Demeanor
The weight rating depends on if your usng a weight distributing hitch. The manual says whats its capable of towing, not what its set up to tow.
Old 02-17-2004, 11:52 AM
SS930's Avatar
I'd go with the class IV so you don't have any insurance issues should you ever need to make a claim.
SS930 is offline
Old 02-17-2004, 12:12 PM
BajaRunner's Avatar
If its already got a class V you should be fine. the usually do like 500/5000 w/out the weight distributing hitch and 1000/10000 with. Ive never used a distributing hitch, but check it out and make sure its a class V. If so, you should be fine.
BajaRunner is offline
Old 02-17-2004, 12:14 PM
Chris288's Avatar
It contradicts itself,,, in one place it says V-5 and on the plate it says 500/5,000
Chris288 is offline
Old 02-17-2004, 12:18 PM
CigDaze's Avatar
Chris.
Important!!! The factory hitch on Ford trucks is only a class 3(500/5000). Despite the fact that there's a "V" on the hitch. The "V" is some kind of part number or stock stamp, not the class rating.
This has come up before.
http://www.offshoreonly.com/forums/s...ck+Class+hitch
CigDaze is offline
Old 02-17-2004, 12:24 PM
Iggy's Avatar
The factory hitch on my '97 F-250 LD says 500/5000 and 800/8500 with weight distribution system and that it's a class V-5 hitch. Owners manual claims a max towing capacity of 8300.
But, the hitch takes a 2"x 2" receiver. Thought class 5 used a larger size?
Iggy is offline
Old 02-17-2004, 12:33 PM
BajaRunner's Avatar
I think the class 5 is still 2x2. man that is misleading as hell.
Old 02-17-2004, 12:40 PM
Chris288's Avatar
Thanks Nick,, that clears this up,, V-5 does not mean class 5, ford seems to be misleading purposely. guess I should be safe and buy the class IV. Just re-checked etrailer.com their class IV is 1,000/10,000. I plan to tow right around 6,500 - 7,000 and should be fine..
P.S. the class IV is 2" x 2".....
Chris288 is offline
Old 02-17-2004, 12:43 PM
SS930's Avatar
Thumbs up
Good call!
SS930 is offline
Quick Reply: Ford F-150 super screw HITCH clarification...
