-   -   Twin Step bunks.... (https://www.offshoreonly.com/forums/general-boating-discussion/72064-twin-step-bunks.html)
spitfire1 02-18-2004 10:28 AM
Twin Step bunks....
1 Attachment(s)
I have a four post lift and it was set up for my 94 Non stepped Top Gun, now that I have the Gladiator I am wondering if this will have any ill effects on the steps sitting on the lift like this??? What do you think???
spitfire1 02-18-2004 10:29 AM
1 Attachment(s)
another shot...
SummerObsession 02-18-2004 10:32 AM
Check into a Myco boat cradle. Cheap insurance for the long run! I'm sure you could modify yours also.
mr_velocity 02-18-2004 10:33 AM
I wouldn't leave it that way. You have two options, either get a Myco cradle for it but it's expenzive or build up the bunks using 5/4" treated wood. Just rip it to the right width. Cut the first piece to it runs from the back end of the bunk back to 6" before the first step. Then run the second piece from the back of the bunk back to 6" before the second step. The bunk should also be square cut and be right under the lifting strakes. You need to slide your's wider.
I've done the wood additions on several lifts including quad step OLs and have also installed the Myco cradle. If you have $4k to part with the Myco cradle is the ONLY way to do. Opt for the service platform on it too.
spitfire1 02-18-2004 10:44 AM
I have seen the Myco cradles...they are very nice no doubt about it...however I have an issue with water depth...and a myco cradle just wont work for me there....I can certainly modify the bunks but I would think it would be a little difficult to get the boat in the same position all the time.....any other thoughts??
jawbreakerkid 02-18-2004 10:46 AM
i did exactly what mr_v suggested to my lift for Speed Racer. works nicely and very inexpensive.
chad
BLee 02-18-2004 10:46 AM
Do not leave it like that bro. It is very stressfull on the steps. Sitting on a lift or trailer not properly fitted will eventually damage your new boat. Just have your lift reconfigured. Shouldn't be a big deal.
spitfire1 02-18-2004 10:55 AM
Anyone in the Ft. Lauderdale area that has done this before??? Or can recommend anyone???
SS930 02-18-2004 11:38 AM
What about Tim G., doesn't he do this stuff for a living? Shoot him a PM.
BLee 02-18-2004 12:09 PM
Who built the lift?
