Konrad 540 HP drive. A better idea!!! >
Old 04-20-2004 | 02:28 PM
  #111
Steve:
We are working on updating the website for the replacement project. This will take some time.
The package is very simple. It can be accomplished in two man days, maybe faster if everything is organized.
Give a call if you have further questions.
Fred Sparling
715-386-4203
FSPROPELLER is offline
Old 04-21-2004 | 09:21 PM
  #112
Good job Kurt! I'll bet it makes a great article.
My brother wants to put Rtech supercharger systems on his 30' cat with 500 HP 502s. Since my system produces 800 HP @ 5500 RPM, I have been putting him off by saying, "No way, the TRS drives won't take it!" Now he has an answer for that. Thanks a lot.
By the way, what was the result with the spacers in? Same as the TRS? You know I need data tables and graphs...
tomcat is offline
Old 04-22-2004 | 06:34 AM
  #113
Biggus's Avatar
Hi Tom,
When comparing "apples to apples" we were surprised to see the Korad 540 was almost 1 mph faster than the TRS. This was very exciting as the 540 has much larger gears, bearings and holds 6 quarts of lube. It goes to show how much more efficient the Konrad lower gear case is vs. the TRS case.
The 540`s would be the answer on Paul's cat and your Supercoolers!
By the way, your Supercooler for the HP500 EFI looks incredible. Keep me posted on the progress.
Kurt
Biggus is offline
Old 04-26-2004 | 05:15 PM
  #114
Biggus's Avatar
The Konrad's really attract a crowd, every time I stopped for fuel someone would ask about the drives.
I'm extremely pleased with them. The attention to detail is amazing. They are made to be maintained with ease, lots of little features like externally replaceable propshaft seals, bronze bearing retainer nut and bronze trim ram end caps.
Check them out at www.konradmarine.com
Kurt
Biggus is offline
Old 04-26-2004 | 07:30 PM
  #115
ned to mod that trailer and protect dem bad boys
open87 is offline
Old 04-26-2004 | 08:03 PM
  #116
Zero Patience's Avatar
I ordered a set from Fred last week after following this post. They are fabricating the wing plates for the steering and will ship at the end of the week.
Zero Patience is offline
Old 04-26-2004 | 09:30 PM
  #117
Audiofn's Avatar
Charter Member #232
Kurt did you make sure you have fresh water Zincs on them? I would hate so see ya have a issue if they are not.
Jon
Put your best foot forward!
Audiofn is offline
Old 04-28-2004 | 11:21 AM
  #118
Audio:
Are you referring to magnesium anodes? Kurt has zinc anodes but have you had trouble in certain environments with the zinc? If so, please describe.
Old 04-28-2004 | 01:32 PM
  #119
ChrisK's Avatar
Moderator
Hey there is nothing wrong with that trailer... I spent the first 22 hours of its road life with that trailer.
ChrisK is offline
Old 04-29-2004 | 07:28 AM
  #120
Audiofn's Avatar
Charter Member #232
Originally posted by FSPROPELLER
Audio:
No I have just heard that you use different zincs in fresh water then salt. I figured since most of Konrads bus is with the navy they probably use the salt water version. Other then that I am just going with what I have heard....
Jon
Audiofn is offline
