-   -   Third generation RX-7 (https://www.offshoreonly.com/forums/general-boating-discussion/72739-third-generation-rx-7-a.html)
JUSTONCE 02-27-2004 09:03 AM
Who's got em? What to watch for when buying, other than the fact they only get 45k on a motor:rolleyes: ?
Cattitude 02-27-2004 09:16 AM
bought a 22k mile 93 car from a Dr. in 99, kept it 4 yrs, strong runner, relatively cheap to insure, 100k miles is not out of the question (sold ours at 50 something)
They are not the most reliable- little things, few shops know them well, like turbo timers and gentle warm ups. apex seals like an oil additive in the fuel. Look up pettit racing in FL- they specialize and have lots of good scoop.
HyperBaja 02-27-2004 09:35 AM
When the motor does go, a rebuild is almost 2k.
SS930 02-27-2004 10:25 AM
The motors aren't that bad, but the turbos do not last at all.
JUSTONCE 02-27-2004 10:45 AM
thanks for the input. I've had a couple 2nd gen non turbo's so I know the rotaries pretty well. If turbos are the biggest issue I'll be o.k. I got a few friends that do custom balancing and work with turbo's So I may just switch to a good single setup.
Cattitude 02-27-2004 10:55 AM
The turbo's are fine if you change your dino oil every 2500 (no advantage to syn here) and use a turbo timer. these are hot running motors, no timer to properly cool at shut down and you're throwing cash away- large amounts. Good luck.
BigSilverCat 02-27-2004 02:49 PM
i went through a couple motors in my rx-7 i only put around 300 miles on it the whole time i owned it, but a .126 nos jet on it did not help.
