Need Fly Wheel Changed in Miami / Ft. Lauderdale
I need to have a fly wheel changed ASAP. Any Help would be appreciated. Boat is in Ft. Laudeardale, but will Travel. Help!!!!
Call Tres Martin at Martin Offshore:
954-587-1220 They do great work! He is in Lauderdale. |
Troy at Supreme Marine can make it happen. 954-797-1818. Make sure you tell him Tim G sent you..
See you at the PR this weekend. |
Tres is good, but you can also try Steve Lopez, he was the crew chief for DeSantis last year. Just north of Ft Laud in Pompano (he rents half our building from us)
954-816-9598 |
Call J.T at TNT MARINE they service sterling for mike. J.t hooked me up on a key west run with a new drive, i hit the slings and in and out in 45 minutes.
Thanks Scott,
J. T. Hooked me up, and is going to fix it in the morning. Be careful of the new little mercury starters, third set out of the box that puked the gear. See you Thursday. First round on me! |
I'LL BE IN LATE ON THURSDAY AND DROPPING IN FRIDAY A.M. AND GOING FOR A LITTLE TEST RUN.
Animalhouse,
Check to make sure the starter doesn't need shims. I had a similar problem, after adding some shims the problem went away. Say hello to Bob |
Originally posted by JimV Animalhouse, Check to make sure the starter doesn't need shims. I had a similar problem, after adding some shims the problem went away. |
Scott,
I'll be there on Thursday night. I am arriving with the OL boys towing pete's boat down. See you in the boat house. |
