boat Launch Backup lights tahoe/yukon
1 Attachment(s)
here is my first Tahoe Mod remove cover off Z71 roof rack, drill Hole for new light.. Make sure you have a light
that will fit this app. |
1 Attachment(s)
mount your light and wire
1 Attachment(s)
now there is some lights :D , I put them on a switch
but with a relay you could put them on your backup light circuit, Dont wire direct to the backup light, Too much current |
Looks cool, does it light up alot in a certain area like a headlight, or just lights up the area like a fog light, thanks Jeff
put a couple 50 watt halogens and it lights up the whole ramp :D I would'nt go much higher because the housing is plastic and might melt with 100s
Beat me to it DJ...looks great!! :cool:
Thanks, looks awesome, sometimes I leave before dawn and have to hook up to a trailer, this will come in handy, Jeff
Lights
I do the same on my trucks, I was wondering why GM didnt do that as a factory option.
Looks great. I wire mine though a relay on a switch and a seperate relay through the back up light trailer harness to turn on by reverse lights and by a seperate switch. |
Re: Lights
Originally posted by Hi-Tech Marine I do the same on my trucks, I was wondering why GM didnt do that as a factory option. Looks great. I wire mine though a relay on a switch and a seperate relay through the back up light trailer harness to turn on by reverse lights and by a seperate switch. wired relay through hot acessory juice so it cannot be accidently left on and drain battery If you have any question as to how to wire have a friend that fully understands auto electric help you |
TOPDJ
I have a set of fog lights on my bench waiting for a nice weekend to do the same set-up. Which lights did you use? Where did you get the power from? |
