Flusher for Bravo 1
Old 04-13-2004 | 11:11 AM
ChrisK's Avatar
Moderator
I use the orange merc hi performace LWP one and it works OK ... It is kind of a pain to connect it and things but it works fine. I dont run in salt water enought to worry about installing a permanant fluch mount in the engine compartment.
ChrisK is offline
Old 05-30-2004 | 09:15 PM
chuck21401's Avatar
Default Re: Flusher for Bravo 1
Originally Posted by FunHome
Ed, I bought one of those last year for about $65.00 and the first time I used it I burnt up a impeller!!! They didn't seem to work as well as the old style "muffs" that's why I was thinking about getting a flush kit!
This happened to me on Saturday! The flush kit looks like a good solution.
chuck21401 is offline
Old 05-30-2004 | 09:24 PM
mr_velocity's Avatar
I had Teague make some beautiful stainless Tees that I put into my intake lines. Since I run offshore pick-up with strainers I have two per engine. One is between the pump and the strainers, that will back flush the strainer and if I need to run the engine it will provide water to the pump. I also have one between the pump and the motor that I use for flushing, since I run a cross over and no thermostat I don't need to run them to flush. With twins, I run all 4 lines to valves that are all tied together so I only need to hook up the hose once. Then go down the line and open each of the 4 valves one at a time, everything is flushed.
mr_velocity is offline
Old 05-30-2004 | 10:53 PM
wwwTOPDJcom's Avatar
and don't forget to run a 3/4 inch outdoor faucet most homes only have 1/2 faucets and use hot tub or rigid hose it don't collapse
wwwTOPDJcom is offline
Old 06-01-2004 | 07:41 AM
Stormrider's Avatar
JC Performance Engines
I've installed the Flush Pro, and it works well so far.
Stormrider is offline
Old 06-01-2004 | 08:51 AM
Love Machine's Avatar
I believe this is a good one.
Temp Flushpro
One thing to note about the Flush Pro is:
1) You have to open the engine hatch.
2) It won't flush the drives, 'cause of the built-in check valves.
3) If you have thermostats then don't wait for your engine to cool, 'cause you want circulation through your engine.
On the flip side, it's a great way to winterize your engines.
1) You won't lose antifreeze through your drives with the built-in check valves.
Love Machine is offline
Old 06-01-2004 | 11:00 AM
Stormrider's Avatar
Flushing of the drives is one thing I was concerned with.
But isnt this true of any flushing device besides muffs?
Old 06-01-2004 | 11:57 AM
In my Sonic the flush kit consists of a basic T joint in-line with the raw water hose (in the bilge). There are no check valves in the T joint. Therefore, with the engine turned OFF and the water hose turned on, the fresh water has no choice but to flush the drives and exit the drive pickups.
This is what Sydwayz was talking about above.
Old 06-01-2004 | 12:31 PM
MnFastBoat's Avatar
Charter Member#157
go to home depot
but a 1 1/4inch pipe T
buy 3 hose clamps
buy garden hose adapter to pipe fitting.
buy garden hose cap. need this to seal when not flushing.
buy what ever reducers to get the garden hose attachment to the right size.
then go to your marina and buy how ever long of an extension you want to bring it to working convenience.
use the adapters to go from 1 1/4 to the garden hose connector.
WALLA
you now have an instant flusher. just remove the cap, install the hose, turn on the water.
once the water is on, it will flow out the drive. Once the motor starts the impeller does its job. I would recommend NOT running it above 1500rpm. You stand to dry out the garden hose or collapse it
I spent less then 15 bucks to do both engines.
only thing different I wish I would have done is to buy a thru-hull fitting like they have with some flush units. That would allow one hose connection for both motors.
But I would not recommend running both at the same time on the same hose anyway.
This Cat is trying to keep up with the Big Dogs
MnFastBoat is offline
Dave1972
6
03-30-2009 04:06 PM
PARADOX
0
02-27-2008 02:31 PM
rslick
13
06-15-2005 11:54 PM
OverkillSkater
1
11-21-2003 08:00 AM
BryanTuvell
13
07-15-2002 03:20 PM
