Why wouldn't the they send out a FYI if nothing else.
Cord your probably right. I Probably do need to send info to the Coast Guard and Boat US , maybe it will prevent at least one fire??
I sent it to factory Tuesday overnight. I guess will see what they will do and say???:eek: The picture with the smoke coming out of it . I plugged it back up just for the picture .it looked like it was dieing it self out:eek: |
Originally posted by CigaretteFirefox Yeow, that was close to disaster! |
We had 2 piers with 120 boats burn to the water level 3 years ago here.They claim it was a battery charger?? They watched it burn. It was no stopping it burn ,allwood piers built in the 1960's Lucky the wind wasn't blowing it would of go the rest..Not a pretty site .
I had one friend loose his but up graded ,He just lost some stuff on the boat that could not be replaced:( Scary:eek: |
The board burned that bad and the fuse/breaker didn't trip????
Bad news. I'd check the fuse/breaker to be sure it's the right amperage. It should've tripped way before it did that much damage. |
DANG Rob....real close call. I remember that fire your talking about...that was a big time mess. Glad you caught it cause your right......it all would have been up in smoke. Hope they get that taken care of......thats redicilous.
Originally posted by Iggy The board burned that bad and the fuse/breaker didn't trip???? Bad news. I'd check the fuse/breaker to be sure it's the right amperage. It should've tripped way before it did that much damage. Iggy they told me at the factory what burned up in it would not have thrown a breaker or the fuse in it. Does not make sense. i hooked it back up and I sat there and let it smoke and it did not throw. the 10 gage wire that went thru the amp meter almost burned out of the circuit board. when I pulled the cover off it pulled out of it. Whether it would of caught the boat on fire dont know . BUTT if it had any fumes in it kaboom!!:eek: I haven't ck the boat circuit breaker and amperage but the charger has a 40 in it. 30 amp charger so seem right. |
Not only mount is saftly, but maybe a heat activated disconnect of some sort mounted right above it would be safe insurance.
Originally posted by Mr. Demeanor Not only mount is saftly, but maybe a heat activated disconnect of some sort mounted right above it would be safe insurance. they said it had a thermal shut off in it .dont know what temp. Maybe it would have to have a FLAME on it to trip it??? Atleast its mounted by the halon |
One word....redundancy!
