Where is the orginal Aqua Buff thread??
I tried a search and didn't come up with the one I was looking for. It was the orginal one that one of the graphics guys first told everyone about it. He even wen't on to tell what kind of buffer they used and how to apply the stuff......
Re: Where is the orginal Aqua Buff thread??
Almost any buffer can be used, I have the Makita 9227C, use the polishing pad..not the wool pad, set the buffer on the lowest speed. Use a paint brush to spread small amounts on...then spray..mist with water to keep it wet. It works wet...does not work if it gets dry. Buff away...wipe excess off with towel...Seal your new wet look shine with a quality wax.
BTW, its the best I've seen or used...I have a pretty new boat so I use the 2000. Hope that helps. |
You can have the stuff. Didnt work at all on mine. Oh, and by the way, their instructions say 2500 rpm minimum. Dont do it, youll be sanding the overspray off the rest of the boat.
| All times are GMT -5. The time now is 05:09 AM. |
