View Poll Results: What oil do you use in your stock power big block ??
25-40
50
8.85%
15-40
28
4.96%
20-50
87
15.40%
straight 40
90
15.93%
straight 30
19
3.36%
syntec
9
1.59%
mobil 1
183
32.39%
amsoil synthetic
45
7.96%
R.P.
21
3.72%
OTHER
33
5.84%
Voters: 565. You may not vote on this poll
Like Tree1Likes
POLL: which oil do you use ?
Old 05-25-2006, 01:10 AM
  #121
Charter Member #94
Gordo's Avatar
My Boats: 1999 Active Thunder 25' Factory 1 Race Edition
Default Re: POLL: which oil do you use ?
I agree that you may be able to run a synthetic oil for a slightly longer period. The problem is most marine engines run very rich, which leads to fuel in the oil, which breaks down the oil, etc...
Tyler Crockett turned me on to Royal Purple years ago and I've used it since. It seemed most of the Factory 1 and 2 offshore race teams used Mobil-1 15w-50 or
Royal Purple 20w-50 unless they were going for a kilo record, then it was 5w-30 or something like that. I no longer use Fram filters on ANYTHING. I will however use AC Delco filters on my trucks and some boats, but nowdays almost all of my boats and my customers boats run Wix Fuel/Water filters and Wix Racing oil filters.
If anyone has a better oil, additive or filter experience, I'm always open to listen and look.
In fact, I'm curious about this "SWEPCO" oil...
Abby-someone
Gordo is offline
Old 05-25-2006, 07:13 AM
  #122
My Boats: all
Pennzoil GT Performance Racing engine oil. 25W50
mrhorsepower1 is offline
Old 05-25-2006, 11:26 PM
  #123
Geronimo36
Panther's Avatar
My Boats: 36' Apache Warrior / 22' Apache Scout
Quote:
Dean, is it a synthetic or regular?
Also, how does it compare to Valvoline Racing 20/50 or their 50w racing oil?
Frank
Panther is offline
Old 05-26-2006, 12:01 AM
  #124
My Boats: 1986 Century Coronado-Cardell
to Blitzkrieg;
Is your dissatisfaction with Mobil 1 based on the regular formulations, or is it based on the "V twin 20w-50" which is the consensus favorite of Hydrocruiser and others?
Please clarify.
Thanks, Jim
vonwolske is offline
Old 05-26-2006, 12:27 AM
  #125
Semper Fi's Avatar
20/50. Or whatever my mechanic reccommends
Semper Fi is offline
Old 05-26-2006, 07:19 AM
  #126
My Boats: all
Frank
Non-Synthetic racing grade oil. I do not use any synthetic engine oils . No comparison in my eyes, but just an opinion also. It is important to match oil pressure and bearing oil clearence according to what your application is, how hard is the engine going to be run, horsepower and load levels, ect. We have been very successful with Pennzoil and we stick with it. If it works for you, then stay with what is working.
Dean
Old 05-26-2006, 08:14 AM
  #127
pkspx's Avatar
ditto
pkspx is offline
Old 05-26-2006, 08:52 AM
  #128
Geronimo36
Panther's Avatar
Dean
Thanks! I may try it on my next oil change.
I read thru the product literature and it say's that it reduces cam lobe wear. Since I have flat tappet cam's this sounds like it could be a good thing for me.
I had synthetic in my motor when I wiped out a cam lobe last season. My engine builder said to only use dino oil after the rebuild.
Frank
Panther is offline
Old 05-26-2006, 10:12 AM
  #129
SORE MEMBER
Wobble's Avatar
My Boats: SeaDoo RXP & RXP-X, Stryker Equalizer 28, Eliminator Daytona Jet
M-1 V-twin - engine, 50 hour changes
M-1 302 - filter
M-1 75-90 - outdrive, 50 hour changes
my engine builder loves it
Wobble is offline
Old 05-26-2006, 09:07 PM
  #130
Hydrocruiser's Avatar
Arrow Re: POLL: which oil do you use ?
Quote:
M-1 302 - filter
....that's because engine builders like to sleep at night without the beeper going off too often...and with all the data we got last season pm'd to me... it is obvious that 50 hour changes are practical with M-1 EP or V-twin!! That dramatically cuts the labor cost and hassle factor as well.
V-twin..is THE 2,000lb gorilla who rules the Offshore Lubrication Jungle.
Hydrocruiser is offline
G-Force
11-29-2006 02:35 AM
