Need Wiring Diagram
I need the wiring diagram for a 93 Chevy 2500 HD turbo diesel.
the circuit that I am looking for is the lock up torque converter . from the computer to the trany. My torque converter wont stay locked up after it heats up. I believe it is a loose wire connection or a bad relay because if I hit a bump in the road it will unlock then lockup again. HELP |
Re: Need Wiring Diagram
Try over at thedieselstop.com those guys can tell you just about anything.
Can also find that sort of info on www.dieselplace.com
Full and comprehensive electrical system in PDF form for all upfitters is located here Between those links, you'll either find the answers already posted, or hit the Ask The Techs section on DieselPlace. Good luck. |
Thanks guys
