-   -   urgent need advice (https://www.offshoreonly.com/forums/general-boating-discussion/84988-urgent-need-advice.html)
hugetime1 08-11-2004 11:14 AM
urgent need advice
this is my first hurricane in florida, what the hell am i supposed to do with my boat?? it is currently on a lift in a canal quit aways away fron the gulf. do I leave it there and tie it down or do get it out of the water, problem is, i don't have a truck.
Hi-Tech Marine 08-11-2004 11:31 AM
Re: urgent need advice
Check the coast guard web site. You may be ok depending on the tidal surge.
There are coast guard organized flotillas to get boats inland and tied with long lines across canals or inland lakes. THese facilitate the tidal rise above normal.
this one seems to be small and you may be fine where you are. Tie loose lines in case the tidal rise is higher than your lift. Use a line at each cleat leaving plenty of slack. You wouldnt want the boat to be so secure to the lift it holds it under water.
robyw1 08-11-2004 11:36 AM
Any chance you can rent a protected dry stack for a day or two? If it is far from the gulf it would probably be okay depending on the height and strength of your lift. However I'm sure there is an OSOer that could help you out with a trailer or something. I wish there was something I could do.
Roby
Ron P 08-11-2004 11:37 AM
Throw out the anchor and batten down the hatches!!!
rchevelle71 08-11-2004 11:42 AM
Not sure of the procedure of leaving it in the water???
Do you have a trailer??
If so, I am sure someone here close to you would be willing to tow it to safety for you, if they dont, I Will!!!
Cord 08-11-2004 12:09 PM
If I had an Apache, I know where I'd be! :D
97BossHammer 08-11-2004 12:14 PM
when you say quite a ways....how far are you talking about.
thedonz 08-11-2004 01:46 PM
I Live In South Florida All My Life So I Survived "andrew" The Best Advise I Can Give Ya Is Put It On A Trailer And Store It In A Dry Storage Place. A Warehouse Would Be The Best. It's Not Worth Taking The Risk Good Luck
Mike Donz Jr
CigDaze 08-11-2004 01:55 PM
Jason,
Get that boat off your lift! You have to move it.
It's not unusual for storm tidal surges to reach 5 or more feet depending on the strength of the hurricane.
Wardey 08-11-2004 02:00 PM
Trailer and in door storage is best. If you have to leave it on the lift, tie it down and raised the lift as high as you can get it. Check your insurance policy!!!! My Pathfinder is staying on the lift with rachet tie downs and raised to it's max. Baja is on a trailer at a lot I own off the water. The Extreme is staying indoors down at the shop. Dave Warden
salesmanship 08-11-2004 02:20 PM
Jason, if you can't get it out of the water put er up as high as you can. Tie it to the lift and cross tie the lift to the pilings to keep it from swinging.
Party Friday Night?
hugetime1 08-11-2004 02:37 PM
terry, if it sinks will you let me use a nor tech for a few years
hugetime1 08-11-2004 02:40 PM
well , i'll tell ya, i just got all my supplies, 2 bottles of rum, 3 cases of beer and some playing cards, hope i don't need anything else. if the water gets high enough you will see me racing down del prado in my hustler looting and carrying on like a drunkin pirate!
DanB 08-11-2004 04:42 PM
I dont know what the tide surge is in your area, but I'm about 15 miles up river from you so it will be safer then you close to the gulf. My boat is on the trailer and you are welcome to keep yours on my lift. I also have an extra trailer if you want to get it out of the water. Run your boat up here and I'll meet you at the ramp. If the storm looks like its gonna hit us I'm towing mine up to Ocala to a friends house tommorow night.
Dan
239 277 3901
CMG 08-11-2004 04:54 PM
does your insurance pay-out surpass your enjoyment level? no, never mind, you'll drive my insurance up too, pull it.
cuda 08-11-2004 05:07 PM
Get it on a trailer. If you don't have a truck, beg borrow or rent one.
nolimits 08-11-2004 07:23 PM
That was helpul.... :rolleyes:
When they hit Long Island I take my boat off the lift and to rack storage. Is that an option for you ??
Shane 08-11-2004 07:37 PM
Drill some holes in that garbage barge and put it where it belongs! ON THE BOTTOM! heckle and banter...banter and heckle!
offthefront 08-11-2004 08:01 PM
we are about 35 miles from the coast South of Jax hi dry 2 acre protected area ..anyone is welcome ....
otis311 08-11-2004 08:26 PM
Im in, Ill be down to join you and sit thru it with you
bajabob38 08-11-2004 08:33 PM
This sound like the place to be.
robyw1 08-11-2004 08:48 PM
I found this, hope it helps.
http://www.boatus.com/hurricanes/brochure.asp
Good Luck
Roby
HotPursuit 08-11-2004 09:46 PM
(1) Check Insurance Coverage
(2) Look at all the new models coming out
(3) Have a Hurricane Party New Orleans Style
(4) Invite lots of friends
(5) Pray that it hits someone else
GOOD LUCK
dockrocker 08-11-2004 11:04 PM
New Apache with the stealth paint job ("so slick, you can't even see it!") or old resin bucket? :D
goob 08-11-2004 11:33 PM
I understand that Sanibel is evacuated. My dads boat is in Fort Myers Beach on trailer covered and he is here in Tn. What can you do? Hope for the best. Everyone be safe down there.
Mike
Keith 08-14-2004 02:38 AM
1 Attachment(s)
Just saw this thread, albeit a little late. During Isabel last September, my boat was on the lift. I had no trailer or truck available.
What saved the boat during the Chesapeake tidal surge was a full boat cover with Gortex stitching, 12 bungee cords and stainless steel hooks. Boat floated 2'-3' above the lift during the storm (only 60MPH winds max) and pulled it back down onto the lift when the water receded. All others in the marina sustained major damage, mostly from coming down off angle to the lift. In case the bungees failed, I had tied 6 lines to the boat (x-cross and springs) to keep it from floating away.
I believe the final estimate was an 8' tidal surge in Baltimore. Without a full cover, I suppose you could still use the bungees as a backup by attaching them to the cleats, but not tight to allow full stretch. The downside is the boat will "sink" on the lift if they stretch to the max and don't break off.
I hope you made out okay.
