1000 Islands Poker Run...Fun and EXPENSIVE!
Hot Boat and I had BLAST a the run. Boat ran GREAT all day! One motor was a little shy on RPM's but didn't pay too much attention thinking probably the tach as all other gauges were A OKAY. Get back to ramp to pull boat out, starboard motor has no reverse. :( Oh well, thinking maybe not too big of a deal, pull boat out, gear case and mid section CRACKED BIG TIME! Bearing carrier backed out, blow out ring damaged prop, but all still in tact. No oil left in drive at all. :( So now I am in the market for 2 new mid sections and gear cases. Time to upgrade to offshore housings and sportmaster lowers. So if anyone has a lead on these items priced right please let me know. :eureka:
Re: 1000 Islands Poker Run...Fun and EXPENSIVE!
Shane, did they just let go from high speed or did you hit one of those large pretty big bolders just under the surface?
Sorry to hear that Shane hope you guys had fun.
How's the new employer treating you? hope all is well. |
Same thing happened to me 2 weeks ago, the lower came lose, almost lost the whole lower. We had to idle for about 4hrs.
Should be fixed next week in time for destin poker run, hope the the storm stays away. Curtis |
How's the new employer treating you? hope all is well. Shane |
Should be fixed next week in time for destin poker run, hope the the storm stays away. Curtis Mid sections are tightened after and before each use. This was a bearing carrrier failure. Good luck getting her back together. Shane |
Shane that sucks bro. Wish I had known you were up there I would have given you a call. At leaste you were limping that one drive along for a while..... Time to head over to scream and fly to get all your stuff...
Jon |
Jon |
| All times are GMT -5. The time now is 03:17 PM. |
