-   -   How Long at W.F.O. ?? (https://www.offshoreonly.com/forums/general-boating-discussion/86778-how-long-w-f-o.html)
Strip Poker 388 09-10-2004 03:31 PM
How long have you held your boat engine at WFO not letting out of it?Balls to the wall in flat water :eek:
How many minutes??
On my 500efi's I have for about 10 minutes and the water and oil temps where all good :D .
Just think about the offshore races that are flat and they never let out of it :eek:
Havasu Cig 09-10-2004 03:36 PM
Re: How Long at W.F.O. ??
100 miles two weeks ago at the Scope run. About 1 hour and 15 minutes broken up by 4 card stops. :cool:
BTW they are 500 efi's.
FunHome 09-10-2004 03:39 PM
Usually for about a hour, back when we raced!! 500hp carb.
It took a while for the oil temp. to get up there, never a problem!! after the race when the oil was hot the oil pressure would be down about 10lbs at idle.
Havasu Cig 09-10-2004 03:40 PM
My oil pressure and temps were all good after the run. 10 pounds seems really low!!
BajaRunner 09-10-2004 03:47 PM
I know what it is but what the hell does WFO stand for? I always thought it was WOT Wide open throttle?
BajaRunner 09-10-2004 03:48 PM
better have a drive shower too :eek:
FeverFan 09-10-2004 03:48 PM
Wide F*cking Open?
GO4BROKE 09-10-2004 06:16 PM
Until it breaks or I win.
pullmytrigger 09-10-2004 06:41 PM
Have held the "Pull My Trigger" smallblocks wide open down a BIG lake up here for 25-30min once, just pinned it and left it there. oil temp was up to about 240 and about 10-15 lbs oil press at idle...milled around for a few minutes after and got the oil temp down to around 180 before I shut it down......told a bunch of car guy friends of mine that I did this and they couldnt beleve it..........done it lots of times for 10 or 15......... ;) :cool:
HyperBaja 09-10-2004 07:11 PM
Continuous? Roughly 3 hours.
Overall...... Carb motor with no computer, since we have owned it I would say majority of the hours (90%) are wfo, 5200 (need a bigger prop, 4600 is where she needs to be)
