Audio ,video guys HELP ! Did I get screwed ?
2 Attachment(s)
I just got this for $26 ....
It is a sharp , LCD monitor . The discription says " Sharp 5.7 Inch TFT color panel for IA application" . WHat is "IA" ? I want to use this for DVD & GPS. Will it work ? WHats up with this funky plug ? It is 2 wires ,flat plastic plug . red and white wires. Can I make it an RCA jack or what ever they call them, so I can plug it into my radio ? HELP !!! :( Thanks , Joe |
Re: Audio ,video guys HELP ! Did I get screwed ?
Red and white, looks like DC power...are there any other connections?
does the white wire have a shield and center conductor?
if so I would say red is hot and the sheild is ground, center conductor on the white if it has one will be standard video in |
Looks like a "refill" for a monitor. As in "just the screen" without the electronics. My guess is that the two wire connector is for the backlight.
If I'm right, it will have a provision on it somewhere for a ribbon cable about 1.5" wide that goes from the screen unit to the electronic driver hardware. Hope I'm wrong. |
You've still got the same question on OFFTOPIC.
I still say it is a DISPLAY only, without the "GUTS" you need to make it work. And you can't just find GUTS unless you manage to locate a complete monitor with a broken panel of the same pixel resolution. Not impossible, but kind of like that needle haystack thing... |
| All times are GMT -5. The time now is 12:10 PM. |
