Supercharged Engines...Life expectancy
I just completed 8 seasons with the same engine. No smoke, knocks, rattles, oil leaks or usage or connecting rods exiting through the oil pan. How about them apples?
Re: Supercharged Engines...Life expectancy
Your suppose to crank it and make it run however... :D
Originally Posted by sutphen30
what motors are they and how many hours total on them of run time.
how much boost, hp? How hard do you run them etc?
now that's what I want to hear......now, my two little friends, are you listening?....I am going to feed you a lot of clean oil and oil filters.......stay healthy will ya......
How much HP. What kind of blowers? And did you build them or did you buy them?
Modified 1150 Dominator. B&M 250 supercharger MSD ignition AFR prepared Merlin Heads Gil Offshore exhaust Crane Hydraulic roller cam pete jackson gear drive Merlin block JE pistons Oliver Billet rods Moroso Offshore pan Weston Machine shop handled the machine work. I assembled and installed. It still idles smoothly at 900rpm and rips up to 5000rpm without a single hiccup. |
Parts list sounds great except for the gear drive.
I've never heard of a gear driven timing set-up lasting very long in a marine application. Harmonics/same rpm @ long duration = short life |
