-   -   Prop-RPM Question (https://www.offshoreonly.com/forums/general-boating-discussion/88377-prop-rpm-question.html)
OldSchool 10-09-2004 07:31 AM
Prop-RPM Question
I'm currently running Bravo1 26 pitch props on my boat. I think they are perfect for all around boating. I spin them at 5600 wot (yes the engines can handle that) and get 51 mph @3500 for the cruise.
I just picked up a set of 28 Bravo1's yesterday. I figure that they will be great for long trips (cruising) but I'm wondering what rpm I should be able to spin them at wot? Also, what speed should I see @ 3500?
Thanks in advance,
Craig
Spicy 10-09-2004 07:35 AM
Re: Prop-RPM Question
I told you they were for my trot line rowboat, and you went ahead and bought them anyway, right out from under me!!!!
BobbyB 10-09-2004 07:38 AM
Just go put that boat in the water and use it.
OldSchool 10-09-2004 07:42 AM
:D :D
I did you a favor buddy!! It would have cost you way too much money for a prop shop to fabricate new hubs to fit on those needledick shafts of your 7.5 HP outboards!! :D :p :drink: :drink:
HotPursuit 10-10-2004 01:09 AM
54 @ 3500 and 5200 @ wot if props are cupped the same.Also depends
where your engines make peak H.P.
HOUSTONPROP 10-10-2004 11:16 PM
we can Lab these props for 200.00 each,let me know!
they will be surley better crusing props and mid range will be alot better,but I am sure they need labbed if you want to turn more rpm's.As they will be somewhat on the low side,if you can turn 5,600
1-877-580-PROP >Darin
