-   -   Carlos Magnum with MB454 (https://www.offshoreonly.com/forums/general-boating-discussion/88571-carlos-magnum-mb454.html)
MESABALANCING 10-12-2004 02:24 PM
Sorry we been busy and haven't been showing completed projects but here is some pics of a Friends magnum we built a 454 that made 585 hp and 560ft lbs of torque he's got it in a 27 Magnum sit down. We tested Friday before the regatta and turned 5500rpm at 71.9 on the gps needless to say this is his first boat and he's tickled with the performance.
http://www.mesabalancing.com/misc/HPIM0206.JPG
Here's a pic of the hull on Friday when we tested he's going to have it gone through and we'll post some new ones later on.
http://www.mesabalancing.com/misc/HPIM0203.JPG
We had a custom cam ground with Ford lifter diameter and the torque was increased considerably over the old cam we had.
Stormrider 10-12-2004 02:43 PM
Re: Carlos Magnum with MB454
Laz, any tips on what was done?
MESABALANCING 10-12-2004 04:22 PM
Stormrider
We did our basic balance and blueprint flowed the heads and ground a nice custom cam for it . It's been a while since I had used a hydraulic flat tappet cam . The intake and carb was a Dominator and Dart . Good Luck Laz Mesa
Minx20 10-12-2004 04:42 PM
Nice output. I think I saw that boat in the North Palm Beach area a few years back, looks familiar. Do you have any idea what the weight of the Magnum is?
E.S.
Smarty 10-12-2004 05:06 PM
Where the second big block? Why one? Two will fit.
gmhdfan 10-12-2004 07:52 PM
How much compression? And what heads did you start with? What RPM did it make those #'s at? Nice job. :cool:
bryanspeedracer 10-12-2004 08:37 PM
Ooooo, that boat sits nice in the water!
Sean 10-13-2004 08:13 AM
laz, nice numbers...but I dont think that boat is a magnum...at least from the rubrail up... :) do you have any stats on the boat? weight? year?
MESABALANCING 10-13-2004 01:09 PM
Guys the comp on the engine was 9.5:1 the heads were gm cast iron that we ported and matched the cam to the cam is one of our customs duration @.050 was 236 int and 242 ex with lsa of 112 and we also worked the area around the flange in the plenum the hull tips the scales at 4600 lbs but whats good is the hull is straight and flat as can be.
madbouyz 10-13-2004 01:23 PM
My exact thoughts too , I would'nt mind the engine though :D
