Anyone have one of these laying around??  Need one. >
Old 10-26-2004, 08:21 PM
Gone Fishin'
Waterfoul's Avatar
Default Anyone have one of these laying around?? Need one.
Oil pressure sender. It's a VDO... Made in Germany That's all it says on it. I broke off the screw that the wire attaches to. I"ve tried several other senders and they all send my gauge in different directions.
'Foul
Attached Thumbnails Anyone have one of these laying around??  Need one.-michigan-vs.-minnisota-017-large-.jpg
Waterfoul is offline
Old 10-26-2004, 08:43 PM
eMotiondriver's Avatar
Default Re: Anyone have one of these laying around?? Need one.
Go to an import car part aftermarket place should be no problem. Seen them on older VW's 70-80's Triumphs, MG, Merceedes etc....
Good luck
eMotiondriver is offline
Old 10-26-2004, 08:45 PM
Or even the small garage that works on the above.
Volvo, Saab also...
Old 10-26-2004, 08:56 PM
Gone Fishin'
Waterfoul's Avatar
I've tried just about every marine supply place around here. Never thought about auto parts shops.
Old 10-26-2004, 09:10 PM
mcollinstn's Avatar
and VDO senders use the same calibrations as another brand.
Can'tremember which one though..
It'll come to me in the middle of the night (I keep a notepad on the nighttable).
mcollinstn is offline
Old 10-26-2004, 09:25 PM
LMFAO
Old 10-26-2004, 09:37 PM
speel chekk this fokker!
puder's Avatar
BMWs use them as well. Make sureits the right pressure range for your guage. I use them on my race car and for the longest time I though i had low oil psi. Turns out they sent me a 0-5 bar instead of a 0-10 so all my reading were half of what they actualy were.
Pardon me, while I whip this out!
puder is offline
Old 10-26-2004, 09:40 PM
Gone Fishin'
Waterfoul's Avatar
Ah Ha! It says 0-10 bar on the steel fitting! And on the opposite side of the same fitting it says 1.93 I never even looked at the fitting.
Thanks puder!
Old 10-27-2004, 06:36 AM
CBPBA's Walmart Greeter
Keith's Avatar
You can also try www.egauges.com for VDO stuff, I purchased some replacement gauges from them last year.
K2
CHESAPEAKE BAY POWER BOAT ASSOCIATION
'http://www.cbpba.com'
"Experience is something you don't have until just after you need it."
Keith is offline
Old 10-27-2004, 06:50 AM
cuda's Avatar
I bought one at Napa. They were proud of it.
cuda is offline
Quick Reply: Anyone have one of these laying around?? Need one.
