-   -   'puter help needed... (https://www.offshoreonly.com/forums/general-boating-discussion/91879-puter-help-needed.html)
Cord 12-06-2004 06:11 PM
For some reason, my computer tries to download everything as a "html" file. I can't seem to rename them either. Naturally, these files won't open correctly. Anybody know how to correct this? Please, if you are going to give me instructions, make them very, very basic. I'm not very computer savy.
jeaston 12-06-2004 06:35 PM
Re: 'puter help needed...
Download them from what?
TopSpin80 12-06-2004 06:36 PM
probably porn
Waterfoul 12-06-2004 06:36 PM
I think the manual says to drop it from 3' to cure that issue. In your case, just slide it to the right about 2' and the 3' drop will take care of itself!! Right into the dining room!!!
jeaston 12-06-2004 06:45 PM
Still laughing :D :D :D :D :drink:
Waterfoul 12-06-2004 06:49 PM
You might even find some pieces of it under that nice new 'fridge your wife bought! And Chester will love chasing the flying debris!!!! Sliding around in the wood floor.... busting into the leg of the dining room table... Ah yes, I can see it now.... :D :D
Cord 12-06-2004 07:01 PM
1 Attachment(s)
Did that fix on the remote the other day. The Packer game sucked. :evilb:
If I try to download a file that is e-mailed to me, it downloads as a .html file. The only way I can download them is if I open the file from it's current location and then do a save as. The other day, I was trying to download some drawing files. I couldn't save them as a valid file because they were always renamed to a .html file. Renaming them to a .dwg file format didn't work. The file was still invalid.
Waterfoul 12-06-2004 07:11 PM
A little frustrated with ol Fravre (or how ever you spell it!!!)
jeaston 12-06-2004 07:12 PM
They may be sending them as an html file.
Ted G 12-06-2004 07:34 PM
The things you are being e-mailed are not associated with the program that opens dwg files. So Microsoft defaults to an HTML and hopes your browser can open it.
You need to go to "My Computer", "Tools", "Folder Options" and then click the "Files" tab. It will show you all your file associations and how to change them.
Cord 12-06-2004 07:41 PM
I followed your instructions, and it appears that the files are correctly associated. I know that I was not sent .html files as I can see the full file name. This particular example was a word file.
Cord 12-06-2004 10:47 PM
It's a combination of the second and third options. This problem does not apply to a specific tile type. It applies to all downloads. It does not matter weither the download is part of a e-mail attachment or a file that I'm trying to download off a web site. The end result is the same. For example; when I look at a e-mail it'll say letter.doc or drawing.dwg or image.jpg. They are never *.html attachments. Now generally, I can't double click on the attachment-I've tried that. I must download it first. My choices are to open it from it's current location or to download the file. Sometimes opening it from the current location works. I always have to try twice though. The first attempt brings me back to the same screen. Sometimes on the second attempt, my only option is to download the file. The option to remotly open it is shaded out. Tonight, I was able to remotly open the file and do a save as. When I try to save the file to the disk, my only option is to save it as a .html file. That's the only file type that is available. Pasting the correct file name and extension into the box only gets me a letter.doc.html file that is invalid. Renaming the file by removing the .html extension does not work as the file still reads as being invalid. The only file type in the pull down is a .html file.
Cord 12-06-2004 10:59 PM
Ok, before I piss off an moderators, I'd swear that I had posted this in the bilge section. I must have clicked on the wrong window. Sorry.
Cord 12-07-2004 07:11 AM
Yea, I've tried the file renaming thing in the past. Even with the correct renamed file extension, the program will not recognize it. I get a invalide file type message.
Cord 12-07-2004 08:31 PM
Yes, you have it correct. My e-mail is not located locally, but is web based. We are also using AOL, not Outlook. When I open the e-mail, the message has been downloaded, but not the attachment. That's a separate process. It does not matter if I'm trying to download a file attachment or a web file, the result is the same. This has been a problem for a month or two. I havn't changed anything, but I've been bombarded with viruses lately. They've always been obvious and I havn't downloaded the attachments.
wwwTOPDJcom 12-07-2004 09:20 PM
AOL STINKS CORD, I rather use outlook 2003 sp1 and a regular High speed connection
Risk Taker 12-07-2004 10:21 PM
Damn.....had to read that title a second time....I thought it said "'Puder needs help"..... :D :D :p
Cord 12-08-2004 07:20 AM
Risk-that thought had crossed my mind. :D
I agree that AOL sucks, but it's free, so I put up with it.
