-   -   Big Block (https://www.offshoreonly.com/forums/general-boating-discussion/92096-big-block.html)
CROWN MAN 12-09-2004 01:58 PM
Big Block
On a 1999 454 mpi with 200 hrs. What should the compression be?
How many HRS. should it be good for, on average? More than a 1000 or less?
Dave M 12-09-2004 02:03 PM
Re: Big Block
I think your compression should be around 150 psi. My 454 Mag puked after about 550 hours. Keep an eye on your riser/manifold gaskets. That's what killed mine. I ran in salt a lot and ran hard.
articfriends 12-09-2004 02:24 PM
Re: Big Block
150-160 psi
Edward R. Cozzi 12-09-2004 10:51 PM
Re: Big Block
Consistent numbers among cylinders is important too.
Don't be alarmed to find 140s.
CROWN MAN 12-10-2004 07:34 AM
Re: Big Block
Should the motor be at temp. when checking?
Griff 12-10-2004 12:05 PM
Re: Big Block
Yes, and throttle at wide open.
CROWN MAN 12-10-2004 01:19 PM
Re: Big Block
So the motor at temp then W-O-T then check?
I`ve never heard about the throttle. what does it do?
Griff 12-10-2004 01:39 PM
Re: Big Block
If the throttle's not open, air can't get in. If air can't get in, it can't get into the cyliders to compress.
