-   -   P&D 24' Classic, what comparable (https://www.offshoreonly.com/forums/general-boating-discussion/92109-p-d-24-classic-what-comparable.html)
captainpete 12-09-2004 05:28 PM
Hello offshore enthusiasts: I am a marine surveyor who has been asked to find a value on a 1979 P&D 24' Offshore type 6 seater"cigarette" powerboat. Propulsion is via stern drive, although I am not advised as to what make and model. Presume it is to a Bravo 1. The manufacturer went out of business some time ago and I cannot find any listings whatsoever. I am not familiar with this particular builder so I do not know what quality of the layup, laminate schedule, etc. Essentially, I would appreciate input on what manufacturer this vessel would be comparable to. If anyone has a photo of this model, it would be appreciated.
SpeedGirl 12-09-2004 06:03 PM
Re: P&D 24' Classic, what comparable
P&D stands for Peter and David
The hull (different deck) is the same as a 24' Pantara....
Unless the boat was re-powered it would NOT have a Bravo 1 on it..... It could either be a pre-Alpha or a TRS drive....
glassdave 12-09-2004 06:28 PM
if you are looking for same year/type boats to compare this P&D to i would look at 24 Excalibers and Panteras. and like speedgirl said it probably does not hav a Brovo on it. could actually have anything TRS, MR/gen1 Alpha, Volvo 280 or even a Sternpower.
captainpete 12-09-2004 06:36 PM
Thanks much speedgirl. I am advised the transom was plugged and punched. A bravo 1 was installed. Am also advised pantera bought the molds. You know your stuff. Thanks again.
captainpete 12-09-2004 07:49 PM
The transom has been plugged and punched (filled and a hole for a B1 cut into it). Really appreciate the response from both you and speed girl.
ScottB 12-09-2004 09:09 PM
Look for Excalibur, twister, jaws, Pantera, older Sunsations, All pretty much the same hulls, you need to take build quality into account. A Pantera in good shape at that age would probably bring 12-15k
