-   -   New Volvo deal (https://www.offshoreonly.com/forums/general-boating-discussion/92366-new-volvo-deal.html)
Pismo10 12-13-2004 05:04 PM
New Volvo deal
http://www.donzi.net/forums/showthread.php?t=37764
J-Bonz 12-13-2004 05:16 PM
Re: New Volvo deal
That rubber boot around the thru hull fittng looks very similar to the OMC's engineering marvel, the stringer!!! Makes me want to run away as fast as i can from this product!!!
Just kidding, It looks very interesting
mopower 12-13-2004 11:16 PM
Re: New Volvo deal
Doesn't look like anything I could use where I boat. Too much crap in the water :(
C_Spray 12-14-2004 07:57 AM
Re: New Volvo deal
3 Attachment(s)
Definitely the result of some big-time different thinking from Volvo. It's strictly an alternative for inboard boats. The big advantages are packaging, weight, there's nothing in front of the props to screw up the flow of water to them, and (biggest of all) the props are directly in line with the water flow. The drive leg is bronze (!!), not aluminum, so it's super-stout. In the case of a really bad impact, it's also designed to shear off at a pre-engineered point that won't let water into the boat. Just like a sterndrive, the boat must be engineered to take the thrust loads where the drive goes through the hull. Unlike the OMC stringer drives, the sealing rings are not bellows - they're just giant o-rings. It's also completely fly-by-wire, including the steering. The other neat thing is that your entire propulsion package comes from a single manufacturer: no finger-pointing in the case of warranty/service issues. Combined with their new diesel stern drive, VP's got some neat stuff onthe market right now.
In the pictures below, the engines are towards the FRONT of the boat. Yes - the props face forward.
Stormrider 12-14-2004 08:35 AM
Re: New Volvo deal
I'm assuming the engines need to be mounted toward the stern, as opposed to straight inboard where the engines are mounted forward.
C_Spray 12-14-2004 08:44 AM
Re: New Volvo deal
That's the idea - the engines go in the lazarette, and all the space under the salon becomes available for storage and staterooms.
fund razor 12-14-2004 08:48 AM
Re: New Volvo deal
I will admit it.
I kinda like Volvo.
But then again, I have OMCs.
Pismo10 12-14-2004 09:23 AM
Re: New Volvo deal
Give it a few years until they work out the bugs, then it will be great in certain apps.
cobra marty 12-14-2004 09:26 AM
Re: New Volvo deal
OK, I'm going to turn around the lower on my bravo and run the propeller facing forward!
C_Spray 12-14-2004 10:28 AM
Re: New Volvo deal
Marty - make sure you don't try to use the thru-hub exhaust in that case....
