oil change kits?
Re: oil change kits?
my step dad has a pneumatic diaphram pump used to change the oil in his 18 wheeler. He tried the oil tube and dipstick one and it didn't work very well. what he is doing now is a long peice of hose attached to the drain plug hole, he leaves this in the boat and plugs the end of it. It takes a little more oil cause of the hose, but it all drains out. with the down the dipstick hose it is hard to get all the oil out. he attaches the big pump to the end of this hose.
the drain plug is the bottom of the pan and it is hard to use that dipstick small hose.
Ernie
Ernie
Merc makes a kit to to just what TopSpin described. Actually, they have two kits, each has a different thread for the drain plug hole. I advise buying both, and taking the one back you don't need. The first time you install it, it makes a mess. Last I knew they cost about $55 per kit.
After that though, its the cats-ass for changing oil. I let mine drain all week, and fill-er-up on Friday.
We use a vacuum system. Hook up to air hose, -27psi, then hook tube to dipstick, and give it a few minutes, done.
I can get pics and the place to buy them from if you are interested.
I have a oil boy or something. (west marine) It a metal gas can looking container with a hand vacume pump. Attaches to the oil dipstick head. Works good and fine , much better if oil is warmed up a bit. I also have a drill driven pump. I like the oil boy better, less hassle and you cn pump it down and walk away from it.
i have the Tempo vacuum type and love it. think i got it at Boat US.
08 OPA High Points Champion
Go for the one that has an electric pump on top of a five gallon bucket. Easy 12v hook up, contains the mess, and gets one of my 575s done in less than 3 min. I got mine at Boat Us-I think it is a Jabsco.
Haven't used the hose attached to the drain plug deal yet to compare, but the 5 gallon and electric pump is so sweet I'm not sure I will need to
Do you want to change ALL of your oil? Or MOST of it?
My vote is for the drain tube. You leave at least 1/2 quart, maybe more, in the pan when you suck it out. I know, as I installed the drain kit on my HP500EFI. I warmed the motor to suspend any particles in the oil, and get them up from the bottom of the pan, then sucked it all out the dipstick until it was sucking air. Then I pulled my drain plug and had what I estimate to be a full quart pour out, into the bottom of the bilge. It was a LARGE mess.
on secon thought the cheapest way may just be to set an oil pan behind the boat under the hull drain plug and then drain the oil into the bottom of the boat and out the back.
note this metod can be very messy and cause major structural problems for the floor and transom of your boat.
just get a fitting that goes from 3/4" hose on one end to your drain plug size on the other and pump from the drain plug hole.... this gets all the trash that is sitting on the bottom of the pan out of the engine and doesn't leave 1/2 quart of old oil in the motor.
here is a site explaining both
http://www.boatus.com/boattech/casey/10.htm
you can buy it here
http://www.greatoutdoors.com/go/prod...ly/amback.com/
you can buy it here
