Merc. 420 eng. ?
What's the scoop on them? Did they have a crank case PSI. problem?,I was told it is normal for them to blow the dip stick up about an inch at WOT.
I have a friend that is looking at a set for his 90 Scarab that has about 1000 Hrs on old 454 mags. For the price he can get the motors for it will be cheaper that rebuilding his, he may have a crack somewhere ( milky oil ) in one motor. |
Re: Merc. 420 eng. ?
nobody knows anything?
1 Attachment(s)
I had one in my old Formula and never had any problems what so ever. They have all the good parts in them (internals) and historically were great reliable engines.
Craig |
No big block should have that much crankcase pressure. It's usually caused by blowby past the rings. That engine would have to be torn down and inspected, possibly rebuilt.
Mine are 420's. 19 years and going strong.
I had this problem on my 454ci 400's that was about 3 years ago ... they dont do it now but they are pretty tired. hope that helps
-Brad |
Lapse...
Rings were obviously worn or some restriction must have been present in the vent system to have oil out the dipstick. I have seen oil present in the bottom of a distributor upper housing before, but it was due to the owner having changed the valve covers and not installed proper breathers. I just freshened a set of HP 420'Sfor a person that had one wipe a cam lobe out, but everything else was in great shape at 600 hours. Cam shaft was just a random case since the lifters looked acceptable, and the other motor's cam was re-used after all the lobes were inspected. These are great pieces for what they were designed to do. OR |
These were great motors! The 454 cubes and the internal performance upgrades to produce this Merc 454/420 hp was a perfect mate to the TRS.The Gil Exhaust, and Crane guts along with the raspy sound of healthy power, is absolutely awesome. I am sure Arronow was proud to be running the iron.
The guy told him Merc. said they all do it and to put springs on the dip stick to hold it down :rolleyes: they only have 206 hrs on them he says, but I don't tink they should be doing this or that merc. would say to put springs on to hold them in.
| All times are GMT -5. The time now is 08:40 AM. |
