F150 or GMC 1500HD?
1 Attachment(s)
I need to buy a truck, for work mostly, but on occation need to trailor my boat(2/4 times a year. She weighs 8k-9k depending on fuel. ANy input would be helpful.
Re: F150 or GMC 1500HD?
3/4 ton. I.E. 2500 or 250
Again congrats on the new rig H. |
Go for the 15 HD... Much stronger drive line than the F150...
Trade that little blazer in to some dealer, far, far away..... Poor little truck! |
3 Attachment(s)
if you have to have a half-ton, get the sierra denali truck, its rated at 10k..... :D
plus you get 4WS....... makes that boat disappear behind you :evilb: :evilb: :evilb: |
Trade that little blazer in to some dealer, far, far away..... Poor little truck! The 1500HD has 3.73 rear and the 2500 has a 4.10, the diesel dosen't make sence because I wont keep it more than 3 years due to business and I won't tow much. |
Just what is the difference between the chevy 1500 and the 1500HD. I have noticed the 1500HD's have the same wheels as my 2500 suburban. How does the 1500HD compare to the 2500? (orHD?)
Russ C. |
Russ C. i think it has the heavier axles and frame but not drivetrain? anybody? |
the 1500HD has Tranny coolers, 6.0 engine heavier springs, I see it as a 2500 with a 3.73 instead of 4.10. I hope R.Addiction chimes in soon and give us the facts.
The Denali has an 8k tow rating all wheel drive no 4ws, that comes from the brochure. |
The Denali has an 8k tow rating all wheel drive no 4ws, that comes from the brochure. 04's are 4WS extended cab 10k tow.... 05's are crewcab, no 4WS, 8100 std tow, 9200 max tow, whatever that means..... tows my 30 spectre everywhere just fine and it whips around dually's at the ramp :evilb: |
Originally Posted by Sean H
that is the 05's, 04's are 4WS extended cab 10k
05's are crewcab, no 4WS 8k..... |
i said the same thing to my dealer.... i wanted a crewcab 4WS..... :(
R Addiction, please help here.
I like the looks of GM trucks more than Ford.
The 1500HD, with 6.0L/3.73 sounds great. I have a 2500HD Crew 6.0L/4.10. The gas mileage is terrible (13 MPG). I wouldn't want to use it as a daily driver. I think the 3.73 would help the MPG and still be good for towing. I had a 1500 Ext. Cab 5.3L/3.73. I got better MPG when towing than I get with the 2500 empty. I'm only towing 5-6K though. If you are driving the truck every day and only towing occasional short distance, you may get by with a 1500. My .02 |
If the 1500HD is a 6.0/ 3.73 then why buy the regular 2500? I have a 2500 Suburban with the 6.0/ 3.73 which sounds like the same thing??? It's tow rating is low, but it does just fine up to 10,000#. Is the load capacity different (ex. tongue weight?)
2005 Gmc Hd 2500 4X4
Axle Code Gt4 3.73 (opt) N/c Axle Code Gt5 4.10 (std) 2005 Gmc Hd 1500 4x4 Axle Code Gt4 3.73 (std) Axle Code Gt5 4.10 (opt) |
2500 STD FEATURES 4X4 CREW CAB
****************************** Air Conditioning, Dual-Zone Automatic Alarm System Alternator, 105-Amp Axle Ratio, 4.10 (Must Code) Axle, Front: 4800-lb Cap Axle, Rear: 6900-lb Cap Battery, HD 600-cca Body, Wideside (Must Code) Brakes, Power F&R Disc Braking System, F&R Anti-Lock Bumpers, Chrome F&R w/Rear Step Carpeting Clock, Digital (w/Radio) Communication System, OnStar Console, Floor w/Storage Console, Mini Overhead Cup Holders, F&R Defroster, Rear Window Door Locks, Power Driver's Information Center Drivetrain, 4WD Engine: V8, SFI, 6.0 Liter Entry System, Illuminated Entry System, Keyless Remote Control Floor Mats, F&R Fog Lights, Front Fuel Tank, 26.0 Gal Cap (6 1/2' Bed) or 34.0 Gal Cap (8' Bed) GVWR, 9200-lb (Must Code) Gauges, Oil Pressure & Voltmeter Glass, Deep Tinted Rear Grille Surround, Chrome Headlamp Control, Auto Lights: Daytime Running, Exterior Cargo & Reading Mirror, RH Visor Vanity Mirrors: Dual Heated Power w/Power Fold, Turn Signals, RH Curb Tilt-Down & Inside & LH O/S Automatic Day/Night Moldings, Body Side Option Pkg-1SD (Must Code) Paint, Solid (Must Code) Payload, 3293-lb (6 1/2' Bed) or 3151-lb (8' Bed) Power Outlets, (2) Radio Equipment, Rear Audio Controls & Headphone Jacks Radio, AM/FM Stereo w/6-Disc CD Changer Restraint System, Dual Front Air Bag Seat, Folding Rear Seats, Leather Surfaced Heated Bucket w/Dual 10-Way Power & Driver's Memory (Must Code) Speed Control Springs, Front: 4800-lb Cap Springs, Rear: 6084-lb Cap Stabilizer Bar, Front Steering Wheel Touch Controls Steering Wheel, Leather-Wrapped Steering Wheel, Tilt Steering, Power Suspension Pkg, HD Handling/Trailering (Must Code) Tachometer Tire, Conventional Spare Tires, (4) LT245/75R16E BSW (Must Code) Tow Hooks, Front Towing Cap: 12,000-lb Max (When Properly Equipped) Trailer Connector, 6-Wire Trans, HD 4-Spd Automatic w/Overdrive (Must Code) Transfer Case, Electronic Shift W/S Wipers, Intermittent Wheel Flares, F&R Wheels, Polished Forged Aluminum Windows, Power General Specifications: 4WD Models w/6 1/2' Bed: WB 153.0"; OL 237.3"; Width 79.7"; Ht 77.0"; Curb Wt 5907-lbs Warranty: 3-yr/36,000-mi Limited Bumper-to-Bumper; 3-yr/36,000-mi 24-hr Roadside Assistance; 6-yr/100,000-mi Limited Rust-Thru. Engine Specifications: Code L18; VIN G; Cylinders V8; Liters 8.1; Fuel Induction SFI; HP 330; Torque 450 Code LLY; VIN 2; Cylinders V8; Liters 6.6; Fuel Induction Turbo Dsl; HP 310; Torque 605 Code LQ4; VIN U; Cylinders V8; Liters 6.0; Fuel Induction SFI; HP 300; Torque 360 NOTE: EPA Does Not Rate Vehicles w/GVWR Over 8500-lbs |
1500HD CREW CAB 4X4 STD FEATURES
****************************** Air Conditioning, Dual-Zone Automatic Alternator, 105-Amp Axle Ratio, 3.73 (Must Code) Axle, Front: 4500-lb Cap Axle, Rear: 6000-lb Cap Battery, HD 600-cca Body, Wideside (Must Code) Brakes, Power F&R Disc Braking System, F&R Anti-Lock Bumpers, Chrome F&R w/Rear Step Carpeting, F&R Clock, Digital (w/Radio) Communication System, OnStar w/1-yr of Safe & Sound Service Console, Floor w/Storage Console, Mini Overhead Cooler, HD Engine Oil Cup Holders, F&R Defroster, Rear Window Door Locks, Power Driver's Information Center Drivetrain, 4WD Engine: V8, SFI, 6.0 Liter Entry System, Illuminated Keyless Remote Control Floor Mats, F&R Fog Lamps, Front Fuel Tank, 26.0 Gal Cap GVWR, 8600-lb (Must Code) Gauges, Oil Pressure & Voltmeter Glass, Deep Tinted Rear Side & Light Tinted Rear Grille Surround, Chrome Headlamp Control, Auto Lights: Daytime Running, Dual Exterior Cargo & Reading Mirror, RH Visor Vanity Mirrors: Dual Heated Power w/Power Fold, Turn Signals, Memory, Curb Tilt-Down & Inside & LH O/S Automatic Day/Night Moldings, Body Side Option Pkg-1SD (Must Code) Paint, Solid (Must Code) Payload, 2766-lb Power Outlets, (3) Radio Equipment, Bose Speaker System & Rear Seat Audio Controls Radio, AM/FM Stereo w/6-Disc CD Changer in Dash Restraint System, Dual Front Air Bag Seats: Leather Surfaced Heated Bucket w/Dual 10-Way Power, Driver's Memory & Split Folding Rear Bench (Must Code) Speed Control Springs, Front: 4500-lb Cap Springs, Rear: 6000-lb Cap Stabilizer Bars, F&R Steering Wheel Touch Controls Steering Wheel, Leather-Wrapped Tilt Steering, Power Suspension Pkg, HD Handling/Trailering (Must Code) Tachometer Tire, Conventional Spare Tires, (4) LT245/75R16E BSW (Must Code) Tires, (4) P245/75R16E BSW (Must Code) Tow Hooks, Front Towing Cap, 9900-lb Max (When Properly Equipped) Trans, HD 4-Spd Automatic w/Overdrive (Must Code) Transfer Case, Electronic Autotrac W/S Wipers, Intermittent Wheel Flares, F&R Wheels, Polished Forged Aluminum Windows, Power General Specifications: 4WD Models: WB 153.0"; OL 237.2"; Width 79.1"; Ht 77.3"; Curb Wt 5834-lbs Warranty: 3-yr/36,000-mi Limited Bumper-to-Bumper; 3-yr/36,000-mi 24-hr Roadside Assistance; 6-yr/100,000-mi Limited Rust-Thru. Engine Specifications: Code LQ4; VIN U; Cylinders V8; Liters 6.0; Fuel Induction SFI; HP 300; Torque 360; EPA City 14*; EPA Hwy 19* *2WD Models; 14/16 on 4WD Models. |
NOTICE THE DIFFERENT GVWR'S AND AXLE RATINGS....... they wouldn't make a 1500hd if it was just the same thing with a different axle ration when they already offer that axle ratio in the 2500hd.......
Thanks, I Think the 1500HD will due for me and save at the pump.
I have a 1500 HD. Heavier spring front and rear. 3.73 rear and tranny cooler. It has the 5.3 and runs well. I have towed my 33 Fountain on a triple axle aluminum Performance trailer. It tows OK, not great. It is a little over the suggested rating and in my opinion, at the practical limit for the truck.
I don't tow hundreds of miles, typically around 15-20 one way. For that it is fine. It may be overkill, but I change my tranny fluid every two years (approx. 20k miles). Mine is a 2000, and I love the truck. |
I bought mine as a wreck and repaired it. You wouldn't know it today and best of all, I have waaay less into it than if I'd bought one perfect. I'll drive this thing into the ground.
Bryan |
| All times are GMT -5. The time now is 07:11 AM. |
