-   -   HP on pump fuel (https://www.offshoreonly.com/forums/general-boating-discussion/95313-hp-pump-fuel.html)
ONESICKGLADIATOR 01-28-2005 07:20 AM
Re: HP on pump fuel
Mecr is a big company that spend 5-7 millions dollars on R&D for there new 1075 engines that runs on pump gas. How come they did not make engines with 1200+ hp to run on pump gas. What I am asking is that if merc spend all this money on engine R&D and only came up with 1075 engines to run on pump gas. How do these others Engine guys build engines that have 1200 - 1600 hp to run on pump gas. I guest it is like putting 5 lbs of sh*t in a 2 lbs bag it will work for a few pulled on the dyno.
Rick OSG
44MTI 01-28-2005 08:48 AM
Re: HP on pump fuel
The Merc's are still running Conventional style heads vs big chief style which I'm told is somewhere between 75-100hp difference. Also the mercs are very conservative on their HP ratings and their set-up. Those two things should put you pretty close to 1200+ Consider you 800's which I asume are pump fuel and Merc only makes a 525hp pump fuel n/a motor.
39NAS-T 01-28-2005 09:42 AM
Re: HP on pump fuel
Rick OSG
They want turn key every day no worries motors. Where other companies are ok with turning it up a notch to get you more hp out if it. Who makes 1600 on pump gas?
Hunter
TylerCrockett 01-28-2005 10:30 AM
Re: HP on pump fuel
We built some 721ci engines with 16:71 Littlefield blowers,Olds heads,innercooled,and Kinsler electronic fuel injection and 16 injectors per engine 8 above the blower and 8 in the intake runners. The engine made 1200HP@ 5500RPM and 1300 ft # of torque on 93 octane gas. We built these engines 5 or 6 years ago.
JCPERF 01-28-2005 11:13 PM
Re: HP on pump fuel
How much boost?
JCPERF 01-30-2005 05:06 PM
Re: HP on pump fuel
Hunter
Who is Hunter?
39NAS-T 01-31-2005 10:25 AM
Re: HP on pump fuel
I am a college student who enjoys to go boating and put go fast items on things that move.
Hunter
