Livorsi tachmomters
Does Livorsi make tachometers for Diesel engines? if that, can you get a mechanical tach? :confused:
Re: Livorsi tachmomters
Most diesel engines today use pulse adapters. A electronic device that the tac drive turns that sends the pulse to tachometer. Allows you to use any tachometer head you want.
Not this one. its a cable that runs from the alternator to the Gage. Old school
The end of the cable has a threaded coupler on it ? Undo the cable at Alt. screw the electronic tac adapter on Alt. Bingo! Some put the tac adapter in the dash. just undo tac cable from tac and put elecronic tac adapter on then wire up any tac you want. The electronic tac adapters we use are Stewart Warner's if I remember correctly.
that might work. SO where do I get one of these adapters? on then theres still the question of does livorsi make a Diesel tach?
heres a pic of the cable. Best i can do. cant get to the one on the truck. too cold to go out and fukk with it :evilb:
http://saturnsurplus.com/m35/0561.jpg |
The last ones we got from NAPA they called it a sender kit Part# 701-1510
Can't help you with the tac head question. |
thanks! hopefully too old will pitch in here and fill me in :drink:
Ttt :d
Have you contacted Livorsi? Their website list them.Livorsi Diesel Tach
They also list several options including mechanical driven. Problem solved. :drink:
:drink: good man.... wonder if they will work with 24 volt :confused:
| All times are GMT -5. The time now is 07:51 AM. |
