Like Tree0Likes
wheel mag lock removal
Old 01-30-2005, 01:30 AM
Default Re: wheel mag lock removal
Torching sounds very exciting, but with my luck the boat might go up in flames-can't do that, the vessel is for sale.
Lubejobs42, thank you for the offer. I may take you up on the offer- I will pm you.
Great advise I will try them all-
Thanks All
Dirck W Gomez is offline
Old 01-30-2005, 03:32 AM
CAP071's Avatar
Quote:
Originally Posted by NASTY HABIT
done the socket thing ...worked fine
Yes Yes I have done this also
or borrow the kit mentioned above
CAP071 is offline
Old 01-30-2005, 07:44 AM
Scott B's Avatar
My Boats: Donzi Criterion SS, X-18 , 16 OB, Z-235, F-14, Magnum Missile
Quote:
Originally Posted by mattjtowne
Its actually $29 and its part number 52165...
The socket works too if you get lucky and get one to fit the lock right.. McGard's are always a strange size.. We use this all the time to remove locks...... The teeth bite in as it turns where a socket wont...
29 bucks is cheap enough, who makes the kit??
Scott B is offline
Old 01-30-2005, 09:37 AM
mattjtowne's Avatar
Quote:
Sears.......
mattjtowne is offline
Old 01-30-2005, 11:53 AM
My Boats: None
Drive a cheap socket over the locknut, use a breaker bar to take it off...
That's what I do.
It isn't pretty, but I don't quit until they're off.
The lock is no good anyway...
Edward R. Cozzi is offline
Old 01-30-2005, 12:09 PM
air chisel. You don't have to cut / split the nut. Just cut a groove so the chisel has something to bite on and then turn the air chisel to drive the lock in the "loose" direction. 30 seconds, no purchase required.
jwbbuck is offline
Old 01-30-2005, 01:03 PM
panteraman28's Avatar
My Boats: 2002 28ft pantera F-1
I had the same problem, used a small pipe wrench worked great
panteraman28 is offline
Old 01-30-2005, 02:24 PM
JCPERF's Avatar
My Boats: 10 foot Kayak
Quote:
Originally Posted by Dirck W Gomez
I have lost my key for my wheel locks on my trailer (dumb huh?) and was wondering if there is a trick way to remove without damaging my aluminum wheels. I have tried vice grips and they just slip off as the lock is tapered out. It is harden steel and I believe it is made by Mcguard.
Put a 41 Apache on the trailer.The wheels will come right off.
JCPERF is offline
Old 01-30-2005, 03:18 PM
ratman's Avatar
My Boats: michelob light scarab, sold, sailor now
this method has served me well over the years...ratman
ratman is offline
Old 02-06-2005, 03:22 AM
Bought the tool from Sears, worked like a charm...THANK YOU
Lubejob42, thanks for the offer, I also now haved a set of my own
Now I can take the boat out...ya hoooo...gotta wait for the sunrise...just 6 more hours :-).
MOERON
03-08-2008 11:28 PM
mark30h
11
03-22-2006 09:45 AM
SunsationalMate
3
03-17-2006 11:17 AM
bikinilover
Baja
13
04-24-2003 09:45 PM
Pure Energy
07-22-2002 12:56 PM
