-   -   Sealing up a Transom (https://www.offshoreonly.com/forums/general-boating-discussion/96385-sealing-up-transom.html)
OldSchool 02-12-2005 09:08 AM
What is the best material to use to seal a hole in a Transom. I'm working on my MiniHawk. The hole is drilled for my drain plug and I need to seal it. Do I use epoxy, 5200 or what?????
Thanks in advance!!!
Craig
GLH 02-12-2005 09:18 AM
Re: Sealing up a Transom
Use that Loran you ripped out of your Cig...
offshoredrillin 02-12-2005 09:22 AM
3M makes that Epoxy that mixes in the tube as you squeeze it out. Stuff is so tough it can be drilled and tapped!!
OldSchool 02-12-2005 09:47 AM
Thanks for the input GL!!! :p :D :D :drink:
I've got 5200 and some Marine-Tex here at the house...Just wondering if that will do or if I need to go to the Store!!
Ted G 02-12-2005 10:00 AM
If your are sealing in a drain plug fitting use the 5200, the marinetex is not pliable enough to retain a seal. If you are filling a hole use marinetex or west system.
Queenie 02-12-2005 10:04 AM
I'd would use a polyester resin with microfiber or epoxy, one of the two. I use 403 or 404 west system microfiber.
OldSchool 02-12-2005 10:52 AM
I guess that I should have been more specific as to what I'm trying to do. I want to seal up the cross-section of wood (2" or so) from the outside of the boat to the interior. I know that I should coat the holes for the drain plug apparattus with 5200, but would the 5200 be sufficient to seal up the wood as well?
R Addiction 02-12-2005 10:54 AM
Your in over your head Craig....I'll be down in a few hours to take that project off your hands!!
Edward R. Cozzi 02-12-2005 11:04 AM
I'm glad you cleared that up because I was going to ask why you were doing away with the drain plug!
I would use some fiberglass resin.
At Sonic we coated all the wood in the cockpit with it and even when we took apart upholstery from 1981, the wood was like new. Now, of course, it's all Starboard.
OldSchool 02-12-2005 11:08 AM
Thanks Ed!!!
