Like Tree0Likes
"Floating Trailer Syndrome"
Old 02-22-2005, 03:19 PM
Dono's Avatar
Default Re: "Floating Trailer Syndrome"
I gots me one of them thar old fashoned steel trailors. never floats.
Dono is offline
Old 02-22-2005, 03:28 PM
cuda's Avatar
Quote:
It will last about two years here in the salt.
cuda is offline
Old 02-22-2005, 03:29 PM
cuda's Avatar
Quote:
Originally Posted by Chart
At the risk of opposing MCollinsTN, try reducing the PSI in the tires to what you had in the prior tires. That's assuming you never overheated the old tires, and they are the same size as your current tires.
Won't make any difference. The tires are displacing the same amount in volume of water no matter how much pressure is in them, provided they are full at all.
cuda is offline
Old 02-22-2005, 03:30 PM
My Boats: 85 Formula 302
Quote:
Originally Posted by Waterfoul
Hey Chart! Long time no hear from.
Been trying to earn fuel money. In fact, need to get back at it.... How's it going up in God's country?
Chart is offline
Old 02-22-2005, 03:31 PM
cuda's Avatar
Every aluminum trailer I've had floated. I just get used to it, of course having an extra hand (Debbie) to swing it back straight helps a lot. Most of the guys I've seen mount pvc covered weights to the frame. I've actually found the floating trailer useful when I back off the ramp. I remember doing that once with a steel trailer in February. Talk about shrinkage!
cuda is offline
Old 02-22-2005, 03:32 PM
cuda's Avatar
Also, with a floating trailer, I've found it will pretty much center itself when driving it on the trailer. I go slow and rock the boat as I pull up.
cuda is offline
Old 02-22-2005, 03:34 PM
Reed Jensen's Avatar
Quote:
Do you swing your scythe from side to side to rock the boat?...........
Reed Jensen is offline
Old 02-22-2005, 04:44 PM
formula31's Avatar
My Boats: 1988 Cruisers 2800 Rogue
4- 25 lb olympic weights on 2 -1" shafts bolted to the rear most crossmember. Put em on to pull the boat. take em off the rest of the time. Helps in the snow in the back of the truck too.
formula31 is offline
bobo1
OPA/The Jersey Boyz
0
04-23-2008 08:36 PM
LEOPAJM
02-07-2008 01:19 PM
Followmygut
2
05-13-2007 11:41 PM
electrical1
11
11-09-2006 09:51 AM
mikesufka
12-26-2002 12:23 PM
