43 SCARAB Questions
I'm looking at a 43 kevlar sacrab without power and drives.
What power and drives would be required to run mid 60's to mid 70 miles and hour. The boat is a 1991 and the hull is in good shape. It is a step up from my Formula 302. Any other negative points I should consider. I have two same kids and am comfortable with a goood rough water boat and don't need to run 90 miles an hour By the way anyone interested in beautifully restored 1982 302 Formula power trannys and drives have only 115 hours , paint and cockpit interior only a year old. Thanks Rick G. |
Re: 43 SCARAB Questions
twins or trips?? brovos or speedmasters?
Twins probably 540 cu in. Haven't decided on bravos or speedies. Might have a deal on number 4's.
Any ideas. Rick G. |
what is the hull cut for now? twin 600 to 650 mid to high 60mph..what boat??their was not that many twins made. is it a larry smith or wellcraft??
It had big power and # 6 drives. A bit out of my league. I don't which hull it would be ,Smith or Wellcraft.It has a full cabin if that helps.
Would TRS drives work in this application , I think they are stronger than Bravos and work well with the BW tranny's. Thanks Rick G. |
i think i know the boat.. its in s. fl. if its the one im thinking of its a great boat!! if i was to do it i would by a set of konrads around 10,000 per side and put about 650 hp.. it would be a bulletproof high 60 mph boat.. myself i would not even consider trs! no parts are out there. unless they are free and later you could change out to konrads or speedmasters.. the boat would live with xrs and mid 600 hp.. but the konrads are the way to go.. good luck james
If It Has A Full Cabin Then It Would Be A Wellcraft. I'm Not 100 Percent Sure But I Don't Think There Were Any Larry Smith With Cabin.
Donz Jr |
James my thoughts exactly. I would only go the TRS route if they were all but free , too bad you can't get parts well not for much longer cause they are strong . I was hoping that 650 hp would get me into the mid 60's . What do you think a pair of bravos would be worth used of course complete with T plates and gimbals.
Thanks Rick G. |
Donz Jr |
i dont know because sometime you can find some good deals then other times people think the stuffs made of gold...i would not put anything under a xz or xr in that heavy of a boat. if its the one im thinking of it is a little lighter, so that helps, as for the speed with brovos and 650 mid 60 should be a no brainer, thur about any water :D
you could always rig it with trs's side by side and use the #6 motor mounts and later sell the trs's and buy konrads that would go in the same holes.. very easy change out and you can find trs gimbles and drives easy with all the people doing the konrad change out
The change up to Konrads would be a good way to
consider the TRS package. I figure I can go The TRS route fairly cheap to start, work the bugs out ,then upgrade when I have a bit more dough. That way I don't have to woory about engine location and mounting as a result of the upgrade. Rick G |
| All times are GMT -5. The time now is 02:50 PM. |
