Underside of Engine Hatch
Old 03-05-2005, 10:07 PM
Wellby's Avatar
Question Underside of Engine Hatch
I need to redo the underside of my engine hatch. It has gelcoat peeling away from the 'glass. Is it safe to cover the underside of the hatch with marine carpet? I have thought about this all day... thinking about pros and cons. Anybody got any info or experiences with this matter?
Wellby is offline
Old 03-05-2005, 10:13 PM
LubeJobs42's Avatar
Default Re: Underside of Engine Hatch
I don't think I would use carpet. I'm using mirrored plexiglass. It's not very expensive and looks great.
LubeJobs42 is offline
Old 03-05-2005, 10:26 PM
Wellby's Avatar
I've got 3 structural braces going across the bottom of my hatch... unless I pull it off , sand(or grind) it down and re-gelcoat it... I'm looking for a little easier option. Although... I have thought about the carpet with mirror in between the braces.???????
Wellby is offline
Old 03-05-2005, 10:29 PM
stecz20's Avatar
heres a few shots...
Attached Thumbnails Underside of Engine Hatch-s-cam-035.jpg   Underside of Engine Hatch-s-cam-038.jpe
stecz20 is offline
hillbilly24's Avatar
carpet is very common on west coast lake boats like the smaller eliminators, coles, and ultras. looks ok but not as nice as gel and mirror, never seen carpet and mirror might look cool post pics if you do it.
hillbilly24 is offline
Old 03-05-2005, 10:42 PM
Wellby's Avatar
I'm just worried about the saftey factor. Too much heat, enclosed area??
Wellby is offline
Old 03-05-2005, 10:59 PM
GLH
GLH's Avatar
That gay mirror must weight a ton and slow you a few mph!
GLH is offline
Old 03-05-2005, 11:37 PM
Wellby's Avatar
That was FIRST THOUGHT... But all the peeling gelcoat/paint?! Other things have a higher priority. Looking for a quick fix for a season or two
Wellby is offline
Old 03-06-2005, 07:12 AM
offshoredrillin's Avatar
Received 1,295 Likes on 449 Posts
I agree with my pal stecz, I wouldnt carpet it for the simple fire hazard. You would have to use a contact cement which is highly flammable even in its dry form, and the material that carpet fibers are made from just turn to goo when flame hits them. Not to mention, you would have to have the edges bound to stop them from fraying, so you would have tu premold the carpet using a steamer, then go back to install. using contact cement you one shot with it, or you peel it all off and start over. just my .02 but, regel it paint it and have a nice day...Rob
offshoredrillin is offline
Old 03-06-2005, 12:34 PM
stecz20's Avatar
quiet old man, you know you like my mirror...
stecz20 is offline
Quick Reply: Underside of Engine Hatch
