Re: Hull bottom gets yellow
Originally Posted by Edward R. Cozzi
Sno-bol toilet bowl cleaner will take off the brown stain.
On-Off will remove the wax. It IS the water, not the dock causing the stain. Unlike a hydrohoist, where the hull is mostly in air, the airdock fully cushions the hull. It has the same PSI on the hull that water has. But therefore the hull is touching the dock on alot of its surface. I'm hoping the waxing helps, becuase i feel the airdock is a great system and is good for the boat. |
| All times are GMT -5. The time now is 07:49 PM. |
