Driv OIL/ Amasoil anyone use it??
I am in the process of rebuilding my drive 350hours, anyway was told I should look into using Amasoil drive oil instead of merc High perf. Anyone know about this or shed some light??
Thanks WILL :D |
Re: Driv OIL/ Amasoil anyone use it??
Teague used to send Amsoil out with his upgraded drives, don't know if he still does or not. I have used it in my outboard lowers and have seen a decrease in temperature and shavings on the magnet over the Merc Hi-perf gearlube. I have used the 80W-90 in the past. Just recieved some of the new 75W/80W-90 Marine Gear Lube. It is supposed to work even better in our application, it will still work when subjected to 10% water contamination per Amsoils catalog. It's worth a try.
Jim at www.nwoffshore.com is a dealer and has researched this subject, you might want to contact him. Just my $.02 Caleb |
I just bought 2 cases, All I run. Ck out my tread in the tech section on where to buy.
use it!!!!
That all I have ever used, I change every 20-25 hours and have never had a drive related problem.
Send a link to order on line.
I have used it for two years now and no problems
I started using it when I read an article in power boat mag, on how to change your drive oil. The mechanic was with merc and he was putting Amsoil in the drive. At least the bottle had a Amsoil sticker on it. Try it.
My question is why use it. I've always used the Merc blue/green stuff without a problem???
Why is it better than the Merc stuff. I'm just wondering. Is it more expensive or cheaper than the Merc? |
I also have been using the 80 -90 wt. At least 6 yrs . Ithough I read somewhere on oso .That 80-90 wt is not avalibabie any more?
| All times are GMT -5. The time now is 10:21 PM. |
