-   -   my tow truck is down and there is a poker run this weekend. help!! (https://www.offshoreonly.com/forums/general-q/100188-my-tow-truck-down-there-poker-run-weekend-help.html)
BajaRunner 04-08-2005 06:59 AM
ok, so the last couple of days, my truck has been running funny. under light acceleration it was fine, but when you punched it, it would backfire through the exhaust. i checked the timing and it was ok. so im at a light yesterday, idling rough, i went to take off and it hesitated. it was around 200 rpms deciding whether to go or die, and about that time it started "dieseling". no start after that. i waited for a tow truck, and right before he got there i decided to turn it over and see what it does. It was the loudest freaking backfire through the exhaust i have every heard. got it towed back, and going to work on it today. weve got a poker run here tommorrow :eek:
the truck is a 1993 chevy k3500 with a 454.
help :(
BajaRunner 04-08-2005 07:48 AM
Re: my tow truck is down and there is a poker run this weekend. help!!
damn, i wish i would have checked last night. i told someone and they assured me it jumped time. so i ripped everything down and the timing chain feels tight. i cant get the cover off, do you have to pull the oil pan to get the timing cover removed? I might as well change the chain while im there. how hard is the ignition module to change. just unbolt and bolt a new one up?
Slick02 04-08-2005 07:50 AM
Loosen the oil pan and drop it down in the front to get the timing cover over the lip on the pan.
Sydwayz 04-08-2005 07:53 AM
Yep, I would put money on the ignition module. Bolt the front of it back up, and go get the module. I have never heard of a motor jumping time. Its a little piece that is in the shape of an apple slice with squared off corners. It sits directly under the distributor cap. 10 minute install.
Oh yeah, label your wires. :D
