-   -   Charging 24 volt system off 12 volts (https://www.offshoreonly.com/forums/general-q/100457-charging-24-volt-system-off-12-volts.html)
482 04-11-2005 09:37 PM
I want to install an inverter in my boat .My friend has one that use 24 volts .How can I use the 12 volt alt to recharge the batteries that run it.Thanks for the help
Airpacker 04-13-2005 02:27 PM
Re: Charging 24 volt system off 12 volts
Theoretically, you can't. You can make or buy a step up transformer that will will convert 12 to 24 but it will cut the amperage in half.
