Trim pump: King Cobra vs Bravo One
Is it possible to use a trim pump from a 1991 King Cobra with a Bravo One. :rolleyes:
Is it the same operating pressure etc. I assume the hose connections won't fit but that is no biggie... |
Re: Trim pump: King Cobra vs Bravo One
Noone?
I dont see why not......if you get some adapters to hook up the pump correctly it should work. Both drives see the same type of force when opperating so i dont see why one would have a weaker pump then the other.....but what do i know! :)
Went the other way, had to have new lines made with the Merc ends on em. Worked just fine....
Ok, thanks alot!
| All times are GMT -5. The time now is 03:50 PM. |
