-   -   Oil t-stat question (https://www.offshoreonly.com/forums/general-q/100999-oil-t-stat-question.html)
kennyo 04-18-2005 03:03 PM
Oil t-stat question
Has any one ran one of these mocal t-stats? I bought one but it had no info with it. I don't know which line to run where. Any help will be appreciated. Thanks. http://www.thinkauto.co.uk/oilstatcolour.htm
Strip Poker 388 04-26-2005 05:25 PM
Re: Oil t-stat question
link not working .
TT
Doug 04-27-2005 12:32 AM
I run those on my Mistress and Top Gun. Look in the end and run the oil from the motor to the spring side. It doesn't matter which direction just from the motor through the spring to the cooler and return through the other half. Motor lines will be on one side and cooler on the other.
Did I confuse you enough. If so let me.
