-   -   Merc BB rod bolts (https://www.offshoreonly.com/forums/general-q/101164-merc-bb-rod-bolts.html)
JanErik 04-20-2005 06:05 AM
Merc BB rod bolts
Hi, I´m rebuilding my BB, but I cant find torque spec for rod bolts, 7/16. There is stamped SPS and a little "C" on the bolts. Any one how can help me.
The engine is in .060 od and using TRW 2399 pistons, weiand x-lerator intake, B&G 750 carb, Stelling headers, rect heads, and some other stuff. This engine is going to run in CC Scorpion 230. Trying to use Alpha drive, but ... I know bravo should be better
MESABALANCING 04-20-2005 07:31 AM
Re: Merc BB rod bolts
If Its A Replacement Rod Bolt For A Dimple Rod It Should Torque To 70-75 Ft Lbs. IF THE BOLTS ARE USED CHECK THEM FOR STRETCH AND MAKE SURE THEY STRETCH EVENLY.
JanErik 04-20-2005 07:58 AM
The bolts are used. How much stretch?
Who is the manufacturer of this bolts ? ARP?
Some data sheet available ?
The camshaft i get with engine has " G0497" stamped,
Somebody know spec for this ?
