manufacturer of lifter in GM 572
Does anyone know who manufactures the lifters in GM's 572 cu in
620 horsepower engine. It has a seat pressure of 197 pounds and it is a hydraulic roller. Seems like alot of seat pressure and I would like to know who makes it. Thanks!!!!!!!!!!!!!!!!!!! |
Re: manufacturer of lifter in GM 572
SPDC notes the cam specs but does not note if it is a soild or hyd roller. Every other crate engine they note cam type.
Your not going to run that kind of seat pressure with a hyd roller lifter for long. In race applications it is possible with restrictor pushrods and a tricked oiling system but for endurance applications I don't know of anyone who has achieved this goal running that kind of seat pressure on hyd rollers. Chris |
I was running 185 seat/440 open per tyler crocketts advice on 610 hyd roller,just tore motor down to freshen w/130 hours,lifters were fine other than some scuffing on the bodys from lifter bore holes being too tight. Motor buzzed to 6000 no problem,My new afr's springs are at 195 seat/460 open but i expect that to drop 5-10% after breakin,i'm running the high spring pressure so i can spin to 6000 and run 12-14psi boost if i want. Cstraub,do you think it's too much? I can get heads cut slightly to lower pressure(i already bought the springs and installed them so i don't really want to buy another set unless i'm guaranteeing catastrophic failure of lifters,Smitty
Daytona30mike
That cam is a Crane Hyd Roller 316*/326* 254*/264* .632/.632 112* The spring run with that cam by Crane is the 99896 135 seat/415 nose Not sure where the 197# number originated, but I would double check the source. Smitty We have run the Morels @ 170# + seat without any problem. Our latest set of AFRs are set up for 180# seat, but I would be careful with your choice of lifter. Bob |
Smitty,
If the spring is made of super clean material the pressure will not drop. Blower engines are diffrent you need to jack up the seat pressure to insure you close the valve and keep it from bouncing on the seat. In your case yes I think 195# is excessive. I would shoot for around 175#. My personal preference would be to run solid roller lifters on the hyd cam lobe with a light lash setting. Chris |
Thanks for the answers... Here is where I got the info...
http://www.sallee-chevrolet.com/Chev...ckV8s/572.html They show it as: 2498792 Long-Block Components (Short-Block Components Plus The Following:) Camshaft 88961557 - Hydraulic Roller (Valve lift: .632” I, .632” E; Duration @ .050” 254° I, 264° E) Lifters 17120060 - Hydraulic Roller Tappet Cylinder Heads 12499255 - Aluminum rectangular port, 118cc combustion chamber Head Gaskets 88961561 Intake Valves 12366987 - 2.25” Stainless steel Exhaust Valves 88963128 - 1.88” Stainless steel Valve Springs 88963934 - Dual valve springs, 1.564” coil dia., 1.800” installed height, 197 Lbs. seat pressure Valve Spring Retainers 12366990 - Hardened chrome moly steel Valve Retainer Key 12366992 Rocker Arms 12361323 - Aluminum roller rockers, 1.7:1 ratio Push Rods Intake 88961559 - High performance one piece Push Rods Exhaust 88961558 - High performance one piece Valve Covers 12499200 - Special 572, Orange Powder Coat Damper 88962814 - High RPM torsional damper SFI approved, 8”. Oil Pan 88963707 Windage Tray New! Screened and louvered Oil Pan Gasket 10106407 Oil Pump 88963707 Spark Plug 05613878 - R45XLS So who do we believe????????? |
Here is a Canadian link with the same specs...
http://www.saturnoflondon.saturncana...html#ZZ572_620 ZZ572/620 Technical Information Horsepower 620 @ 5500 RPM Torque 650 @ 4500 RPM Max. Recommended RPM 6000 RPM Compression Ratio 9.6:1 Block New! Sportsman Tall Deck Bowtie Gen VI 10.200" deck height Bore 4.560" Stroke 4.375" Crankshaft Forged 4340 steel Connecting Rods Forged 4340 steel, H-beam style, Shot peened Pistons Forged aluminum, Full floating wrist pin Piston Rings Plasma-moly rings Camshaft Hydraulic roller Valve Lift: .632" I, .632" E Duration @ .050" 254° I, 264° E Lifters Hydraulic roller tappet Cylinder Heads Aluminum rectangular port 118cc combustion chamber Intake Valves 2.25" Stainless steel Exhaust Valves 1.88" Stainless steel Valve Springs Dual valve springs 1.540" coil diameter 1.800" installed height 197 lb. seat pressure Spring Retainers Hardened chromemoly steel Rocker Arms Aluminum roller rockers 1.7:1 ratio Push Rods High performance one piece Intake Manifold New! Aluminum tall deck single plane 4150 series carburetor Carburetor 850 cfm, mechanical secondary Rear Main Seal New! One piece design Windage Tray New! Screened and louvred Damper High RPM torsional damper Distrubutor H.E.I Fuel 92 Octane Spark Plugs R42XLS Ignition Timing 36° total advance I just find it hard to believe they are doing this kind of seat pressures on a hydraulic roller. |
Daytona30mike,
Not a question of who to believe, just correct information. The spring rate listed is in line with all other aftermarket springs at the 1.800” point. Here are spring forces rated at 1.800” Comp 929 (Stack 1.180”) 1.800 185# Crane 99896 (Stack 1.085”) 1.800 182# Isky 8205 Stack (1.170”) 1.800 185# Isky 9905 Stack (1.160”) 1.800 212# Manley 22429 Stack (1.180”) 1.800 187# Manley 221432 Stack (1.200”) 1.800 206# The question, is GM actually using a 1.800” installed height with a .632” max lift cam to net a 1.168” open? As you can see that is well beyond the .060” safety factor for coil bind on all listed springs. Not many BBC heads being set up with 1.800” IH Bob |
My 929's comps setup at 145 at 1.900
Originally Posted by rmbuilder
Daytona30mike
That cam is a Crane Hyd Roller 316*/326* 254*/264* .632/.632 114* The spring run with that cam by Crane is the 99896 135 seat/415 nose Not sure where the 197# number originated, but I would double check the source. Smitty We have run the Morels @ 170# + seat without any problem. Our latest set of AFRs are set up for 180# seat, but I would be careful with your choice of lifter. Bob Rob |
| All times are GMT -5. The time now is 11:15 AM. |
